where did everybody install their amps?
Old Jan 26, 2007 | 04:53 AM
Sciontized's Avatar
Default where did everybody install their amps?
Hello all, I need some ideas where to install my amp. Thanks!
Old Jan 26, 2007 | 04:55 AM
Neothin's Avatar
i'm building a flase floor and placing them underneith. I'm going to cut some rectangles out of the false floor and router in some edges into those and lay down some plexiglass to see the amplifiers underneith. Light with cathodes and i'm set.
Old Jan 26, 2007 | 05:08 AM
KINGxOFxSKA's Avatar
Unique Scionikz
You make it sound easy.
rocketgyrl's Avatar
Old Jan 26, 2007 | 05:10 AM
BuddhasTC's Avatar
^^nice idea...
Mines behind the rear passenger seat...attached to the back of the seat
Neothin's Avatar
it is easy!
Old Jan 26, 2007 | 05:17 AM
jrodTc's Avatar
haha, yes he does.
Old Jan 26, 2007 | 05:28 AM
Neothin's Avatar
bah, building the box is the hardest part of my whole audio system build just because i had to be so exact with the measurements and cuts. wiring is time consuming, carpeting is time consuming, building the trunk is time consuming, and nothing more.
Old Jan 26, 2007 | 05:29 AM
rocketgyrl's Avatar
Heh...like this, but with amps:
Old Jan 26, 2007 | 06:02 AM
llblutigerll's Avatar
Old Jan 26, 2007 | 12:34 PM
nebster's Avatar
my amp rack isn't quite done yet but i finally got the amp done. it will be lit up and flush mounted in between my two 16ov.2's heres a picture of the amp.
Old Jan 26, 2007 | 04:12 PM
Neothin's Avatar
took off the powdercoated top and put plexi in its place? NICE!
Old Jan 26, 2007 | 10:09 PM
Dr_Isotope's Avatar
Old Jan 26, 2007 | 10:32 PM
ichibansf's Avatar
Picture courtesy of Toast89:
The tools from the top of the spare tire fit nicely in the l/h foam container, picture here courtesy of Golden86:
Old Jan 27, 2007 | 03:15 AM
Sciontized's Avatar
Originally Posted by Dr_Isotope
hey Dr Isotope, does your amp fit in the tool section without any cutting? I have a kicker amp, but it won't fit without some cutting to do.
Old Jan 27, 2007 | 03:40 AM
Dr_Isotope's Avatar
Fits in the passenger side foam without cutting, but the driver's side compartment (the tool side) is pretty much to small for anything. Except the tools, of course.
Old Jan 27, 2007 | 04:16 AM
htowntc's Avatar
Default SEAT
i Put Mine under my front driver side seat
Old May 15, 2007 | 06:36 AM
Adidude's Avatar
As long as they fit I will install mine behind the rear panels like Rocketgyrl. They should since they are fairly small amps.
Old May 15, 2007 | 06:47 AM
GammaTNT's Avatar
Old May 15, 2007 | 04:59 PM
Tcguy85's Avatar
right on the back of my box....
SuBSiN
Mar 13, 2015 04:02 AM
TJ
27
Feb 8, 2004 12:20 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
bluxb
Nov 22, 2003 04:56 PM
shaefner
12
Oct 8, 2003 01:46 AM
