Upgraded 16'' to 17'' but do not fit.. suggestions.
Old Feb 1, 2007 | 07:34 PM
nguyenerrs's Avatar
Default Upgraded 16'' to 17'' but do not fit.. suggestions.
i have 16'' on my scion xa 2006 right now and i order Tenzo 17x7'' 215/40 . its a 4-hole bolt pattern and so is the Tenzos and for some reason it doesnt fit.. i ordered rims from that site before and the following specs are the same accept the tire size. Well my main problem is the center piece where the 4-bolt pattern is will not fit onto the car, it's too big by 2-3 centimeters. Is there anything i can do to make it fit onto the vehicle? i have two options here is finding the answer from the SL community and i just talked with the company that i bought it from. They're going to inspect the pictures i gave them and find a solution... im not screwed or anything i just wanted the damn rims to fit on my car so i'd be on my way and not have troubles .
here's a few pics for my explanation if you guys dont follow me..
bolt-patter on my car
17x7" Tenzo not fitting
16x7" Kobe Wheels fit perfectly (current wheels)
Old Feb 1, 2007 | 07:39 PM
jsa3mm's Avatar
xBs and xAs have a 4x100 bolt pattern. Did you accidentally buy the wrong bolt pattern? I see that it's a four bolt pattern, but that's not enough to determine if it's correct. It should be 4xsomething. The whole that the center cap covers may not be large enough for the hub opening.
Old Feb 1, 2007 | 07:41 PM
evosky's Avatar
you might have gotten the 4x111 thinger bolt pattern. check that again. those specs will make a difference on sizing, which of course you know.
Old Feb 1, 2007 | 07:51 PM
jsa3mm's Avatar
Do you realize there are 2 different bolt patterns on the Tenzo wheel?
Old Feb 1, 2007 | 07:57 PM
dudehitt's Avatar
I think those wheels have 4x100mm and 4x108mm bolt patterns. Rotate them to the next hole and they should work.
Old Feb 1, 2007 | 07:58 PM
jsa3mm's Avatar
I looked it up and if those are TenzoR Mean-6 wheels it's a 4x100/115 bolt pattern on them.
Old Feb 1, 2007 | 08:08 PM
dudehitt's Avatar
oops, I though I saw 4x100/108
either way they should fit.
Old Feb 1, 2007 | 08:09 PM
burstaneurysm's Avatar
Yea, just move it over to the next hole... It's a pseudo-universal bolt pattern.
Old Feb 1, 2007 | 08:42 PM
nguyenerrs's Avatar
im really sure that i cant make it fit . i measured the space between my 16 and 17s and the bolt pattern of the 17 is about 2-3 centimeters larger. i can try again..
Old Feb 1, 2007 | 09:38 PM
There's eight holes in your new wheels. One set is for the 100mm bolt pattern, the other is a 115mm. If you set the wheel and it's too big, move to the next hole in the wheel, this will move you onto the 4x100. That is the correct bolt pattern for the xB. Good Luck
Old Feb 2, 2007 | 03:01 AM
moonray's Avatar
Egads guy's -- There is no such thing as a 4 x 115 mm bolt pattern. The wheel appears to be a dual drill wheel -- 4 x 100mm and 4x 114.3mm. Very common for Honda crowd - civics and older accords. Also fits nissans. Alot of wheels have this common "dual" bolt pattern. Cheaper for the manufacture to make.
Please try again -- their bound fit.
Old Feb 2, 2007 | 03:11 AM
Mouse's Avatar
Default wheels on your xb
what some others saying about moving to the next hole and it will line up that is possible depending on the wheel.... and yep, it's a cheaper way for them to make them. I would also make sure you have the correct offset for the wheels too. when you are going to a larger wheel, that is very important too. you may need positive or neg offset depending on your inner and outer dimentions of your wheel well.
Old Feb 2, 2007 | 03:17 AM
raceronabudget's Avatar
i'm sorry, but if you dont even realize that there are two different bolt patterns on the new rims you have, you shouldn't even be ordering your own wheels. you obviously dont know anything about bolt patterns, which is the bare minimum you need to know about wheel fitment.
Old Feb 2, 2007 | 03:21 AM
Mouse's Avatar
a good place for you to start is there is a good article on proper aftermarket wheel fitting in Import Tuner Magazine, I believe it is the December 06 issue. check it out!
Old Feb 2, 2007 | 04:15 AM
Yea, it's been a long day at work... I guess I just rounded up for simplicity sake.
The underlying case remains that they are dual bolt pattern and the OP is just using the wrong set.
Old Feb 2, 2007 | 04:23 AM
SquallLHeart's Avatar
suggestion? turn it...
perhaps have a small sibling help you.
Old Feb 2, 2007 | 04:56 AM
bB2NER's Avatar
Music City Scions
Easy fix just by looking at your pics. Do what others said. Use the smaller (closer to the center) set of holes. They should be 4X100. My last set of wheels had the 4X100 and the 4X114 dual lug pattern and I always just used the smaller spaced set of holes. Good luck unless neither set of holes are 4X100. Then you got the wrong wheels!
Old Feb 2, 2007 | 05:10 AM
hahaha
Old Feb 2, 2007 | 02:03 PM
dudehitt's Avatar
I knew it wasn't 115, but didn't think I needed to correct him. I went back and looked again and those wheels come in 4x100/114.3 and 4x100/108. Either way they should fit with no problem.
Old Feb 2, 2007 | 10:57 PM
nguyenerrs's Avatar
well yeah call me an idiot all you guys want i'm calling myself an idiot too lol . and thanks for all the support and suggestions. IT DOES FIT . the 4-bolt pattern is universal and it fits for both sizes. to be honest i just gave up after going for that ONE hole that i wanted to fit and didnt bother trying anything else . yea yea imma klutz thanks had a brainfart . ill post pics when it gets dark.
