View Poll Results: What is the status on your aftermarket headers?
I installed aftermarket headers, and I've never had a CEL.
0%
I installed the headers, I have a CEL, but I ignore it.
31.25%
I use a mechanical (screw on thing that moves the O2 sensor back) anti-fouler that has fixed my problem entirely.
62.50%
I use a fancy electronic anti-fouler and it has solved my problem.
0%
I've tried every fix and I still have a CEL. I'm either unlucky, or I hurt my O2 sensor somehow.
6.25%
Voters: 16. You may not vote on this poll
Header CEL Situation Round-Up
Old Feb 4, 2007 | 03:08 AM
scootermafia's Avatar
Default Header CEL Situation Round-Up
Well, since my headers are on the way and I'm fairly worried about the CEL situation (I have a mechanical CEL screw-on anti-fouler coming also) I figured I'd survey the whole board to see where everyone is at. As most of you are well aware, adding aftermarket headers chops the first cat in the TC off, making the secondary O2 sensor in the s-pipe unhappy.
If this is useful, maybe we can sticky it and get closer to an understanding of how widespread this problem is.
Old Feb 4, 2007 | 03:21 AM
NightShade's Avatar
This is a great poll. I just got my dc headers today for really cheap but I am concerned about the CEL and inspection here in Maine when April rolls around. But since its taking the 1st Cat away, I might just as well keep it only for show time. I hope people respond to this.
Old Feb 4, 2007 | 03:22 AM
11thhour's Avatar
i dont have header anymore but when i installed the dc header i installed the antifoulers as well and never got CEL...
im thinking its a hit or miss kinda thing...
my friend's s2000 threw a CEL when he removed his cat even when he used antifoulers... different car but... idk
which company u got?
Old Feb 4, 2007 | 03:26 AM
Generic DC Sports headers. Yes, I got them from ebay. Yes, I will have them and their flanges tested before I put them on.
Old Feb 4, 2007 | 03:40 AM
NightShade's Avatar
wow, no probs huh. Did you ever get it inspected with the header on with the antifouler? id it pass even without the CEL? I'd like to know.
Old Feb 4, 2007 | 06:22 AM
Dakine's Avatar
Concept in Motion Crew
I dont have a CEL either and i have a 2nd hand AW header. Just make sure you spray the antifouler before unscrewing.
Old Feb 4, 2007 | 06:43 AM
KINGxOFxSKA's Avatar
Unique Scionikz
megan racing header + antifouler mod = no CEL here.
Old Feb 4, 2007 | 06:49 AM
TC_by_TRD's Avatar
hey guys im buyin headers soon and dont want my cel on so what is this anti fouler thing about where do you get it and how do you install it thanks guys
Old Feb 4, 2007 | 01:31 PM
NightShade's Avatar
what did you spray it with?
Old Feb 4, 2007 | 03:35 PM
check ebay for "scion O2". And what do you spray it with??
Old Feb 4, 2007 | 04:23 PM
Unique Scionikz
I used WD-40 when i sprayed mine.
Old Feb 4, 2007 | 07:36 PM
NightShade's Avatar
When I think about it, i recall my state inspection officer telling me I cant touch my cat, and since its on the header I wonder if I can change the mid pipe with the 2nd cat.
Would using an anti-fouler that pushs the senosr back fail inspection?
Old Feb 5, 2007 | 03:42 AM
You only use an anti-fouler if you have put on aftermarket headers, which chop off a cat. This, thus, will not pass an inspection.
Old Feb 5, 2007 | 04:36 AM
NightShade's Avatar
wow, then I guess my DC sports header is for nothing, But I know mods when Im on my way to shows are okay. I read something like that about other mods in my state inspection manual that was in pdf format.
Old Feb 5, 2007 | 01:36 PM
tCduck's Avatar
I posted that I didnt have a CEL after the Antifouler but when I got the custom catback the CEL came on about 400 miles after. I restarted my ECU and havent had a CEL yet and after about 500 miles now.
Old Mar 20, 2007 | 10:14 PM
Kall's Avatar
Stock exhaust + Megan header
I got the cel with 40 miles. Then I installed the antifouler and got my CEL at around 185. I reset the ECU to see how long it will last this time.
It seems that the only header that causes this type of problem is the Megan. DC sports and AW are working fine with the antifouler, apparently. Therefore, someone with the Megan header who does not have the CEL on, please share the trick!
Old Mar 22, 2007 | 02:37 PM
tCduck's Avatar
I have OBX headers that cause the same thing.
Old Mar 22, 2007 | 02:59 PM
Kall's Avatar
Those of you still looking for a solution or for instructions on how to do the antifoul trick, check the thread bellow. It's more likelly you will get an update there...
https://www.scionlife.com/forums/vie...=asc&&start=40
Old Mar 24, 2007 | 03:50 AM
HP_Pirate's Avatar
I have a megan racing header V2, been on for over 7500 miles. use a mechanical antifouler made by yours truley. been great no check engine light up untill about 100 miles ago. got a code for secondary o2 no signal. pulled out my anti fouler and the small hole on the bottom was plugged with carbon build up. cleaned it off and has been great since.
Old Mar 24, 2007 | 10:51 AM
MrChoyBoi's Avatar
What did you clean it with?
