younganimater35
02-07-2007, 03:08 PM
I've read on some sites that an increase in the throttle bady space would increase airfolow, i'm a little skeptical to this. And also about running a different hose around the throttle body to recieve cooler air.
View Full Version : Throttle Body Spacing younganimater35 02-07-2007, 03:08 PM I've read on some sites that an increase in the throttle bady space would increase airfolow, i'm a little skeptical to this. And also about running a different hose around the throttle body to recieve cooler air. Simmo 02-07-2007, 05:47 PM yes. increasing throttle body you obviously provide bigger opening for airflow, thus more air goes in = more HP.. Plus, sometimes aftermarket throttle bodies are not only big, but also more responsive.. Basically, its good. As far as the hose around the throttle body??? what hose? you mean the intake pipe? if yes, that would be the cold air intake that you need to get. aveosam 02-07-2007, 10:27 PM with the hose i think he is talking about the throttle body coolant hose bypass Simmo 02-07-2007, 11:22 PM oh.. well in that case, i dont really think it would make that much of difference if you change that hose. I wouild think, if you are putting bigger throttle body, bigger coolant hoses (in/out) wouldnt be a bad idea, but the effect wouldnt really be noticible. Wouldnt hurt though. jct 02-08-2007, 05:09 AM i would of thought of this hose its a emissions hose... that goes to the charcoal canister or the other vent hose of some sort i think... http://i19.photobucket.com/albums/b156/hornet_on_the_flower/my%20car/ugh/P8270002.jpg http://i19.photobucket.com/albums/b156/hornet_on_the_flower/my%20car/ugh/P6010027.jpg younganimater35 02-08-2007, 06:31 PM yeah bypass hose, sorry. but it shouldn't hurt anything? comedykills 02-08-2007, 07:51 PM just a quick f.y.i. there has been no proven benifit from adding a larger TB or a spacer to our motors since they are pretty much at the max n/a airflow Ashe_WCM 02-13-2007, 01:45 AM If the hose runs to the charcoal canster its just venting gas fumes into the intake plenum during higher rpm driving, it is an emissions device that doesnot hurt anything scion04xb 02-13-2007, 02:07 AM Well I saw a throttle body spacer somewhere on here that spun the air that comes in after throttle body. I would think it would help gas milage a little bit. My dad put one on his 4.0L jeep and it made a 2 mpg diff but thats a way diff motor type and all.... So it mite, it mite not help..... I say do it and report back any gains you find if any.... jct 02-19-2007, 02:52 PM Well I saw a throttle body spacer somewhere on here that spun the air that comes in after throttle body. I would think it would help gas milage a little bit. My dad put one on his 4.0L jeep and it made a 2 mpg diff but thats a way diff motor type and all.... So it mite, it mite not help..... I say do it and report back any gains you find if any.... that jeep probably has a TBI where it will benefit with TBI spacer scion04xb 02-19-2007, 04:58 PM nope its multi port fuel injection. Its a 2001. I will still benifit from it a bit. The air will pass through the throttle body butterfly then start to spin and should spin all the way into the combustion chamber. Atleast thats the idea behind it. It does seem to help. As for our cars maybe not just because they are burn most to all the gas already. I have noticed on my car the exhaust doenst have much carbon build up. Which tells me that it runs very well. younganimater35 02-19-2007, 06:37 PM ok well how then could i get quicker response out of it? jct 02-19-2007, 07:27 PM for quicker throttle response get one of these http://www.ecotekplc.com/cb-26p.htm i have one you can see it in my first picture up top there beigemonito 03-09-2007, 05:52 PM what does that ekotek thing do exactly? uber-xA-RS2 03-09-2007, 10:26 PM The thing looks almost like a breather filter. :ponder: jct 03-09-2007, 11:57 PM improves mpg, improves emissions, improves throttle response, and it sort of sounds very small bov/turkey call btw you can see it in the first picture up top there DriverXa 03-10-2007, 03:57 AM a bigger throttle body will give you power gains, but a spacer is an absolute waste of money. think about this a throttle body spacer is like a carb spacer and you would figure they both work the same. a carb spacer allows the fuel that is poorly squirting out of the carb to have more travel giving it more time for the air and fuel to mix better allowing for a better combustion netting more power. now how does this work on fuel injection? it doesn't since the injector spray the fuel in a fine mist before the intake valves having a far supperior air fuel mixture. just adding a spacer to the throttle body will have pretty much no effect in helping to better the air fuel mixture or adding more air. save ur money on something else that will have an actual effect in power and not some pretty overrated slab of aluminum. kimgt 03-11-2007, 06:59 AM agreed^^ |
