20" rims?
Old Feb 10, 2007 | 06:05 AM
blazinhotboy's Avatar
Default 20" rims?
i want to put dubs on my box. whats the best rim size and tire size should i look for? can someone help me out with some pics.
Old Feb 10, 2007 | 06:06 AM
Neothin's Avatar
ask redneckwithanxb
Old Feb 10, 2007 | 06:10 AM
RedneckwithanxB's Avatar
nothing wider than 7.5
offset 32-38
tires
225-30-20 in the front 225-35-20 in the rear (bigger tires in the front rub like a bith) back give you more cushioning
be ready to roll your fenders and cut the side skirts a little
loose your front inner fenders
and your rears
DO NOT DROP THE CAR MORE THAN 1.5 ICHES... I WENT WITH TANABE NF 210S
DROPPED
hope that helps
Old Feb 12, 2007 | 11:40 PM
el_chapin's Avatar
if you go with the tis 02 or 03 with bfg's 225 30 r20 you will not have to roll or mod anyyhting
Old Feb 16, 2007 | 04:34 PM
BurxBox's Avatar
Question for redneck. If you went with a 42-45 offset you wouldn't need to roll the fenders right?
Old Feb 16, 2007 | 06:23 PM
you would have problems with rubbing on the inside of the wheelwell then
Old Feb 17, 2007 | 09:21 PM
dredge38's Avatar
You can go with a 45 offset and ive had the rears dropped around 2.5 on coilovers, and it tucked the tire (30 Series) the fronts hes right you can do maybe a 2 inch drop but you cant take corners quick if theres a bump cause youll rub, im at a 1 and 3/4 in front and a little lower than that in the rear pics in my profile i believe, also the wheels are up for sale!
eujin
Feb 23, 2016 01:18 AM
axB
Sep 18, 2015 06:11 AM
peruviann
Sep 14, 2015 06:35 AM
Robineileen324
Sep 14, 2015 06:21 AM
JZA70
Sep 12, 2015 09:37 PM
