Powdercoating offer... gauging interest!
Old Feb 11, 2007 | 05:30 AM
t_urbo_C_harged's Avatar
Default Powdercoating offer... gauging interest!
My friends and I are about to start up a powdercoating business and were seeing how much of an interest it was to people. I know that I will be doing my valve cover, Ingall's "stiffy" engine damper brackets, etc etc. Colors would be anything you wanted, cost would have to be worked out when we go into business. We do now have access to facilities that will enable us to do any sized rim as well... let me know if you are interested, what you are interested in getting powdercoated, and maybe what price range you are looking for. Lemme know what you think!
Old Feb 11, 2007 | 05:34 AM
captainlaziness's Avatar
<--- Interested.
Stiffy brackets, valve cover, maybe my stock wheels.
I'd pay ~$50 a wheel and say, $75 for the valve cover and ETD brakets.
BTW, you probably should've put this in PPC.
Old Feb 11, 2007 | 06:23 AM
Originally Posted by captainlaziness
<--- Interested.
Thats great! Thanks for your input/interest... just one question, what is the PPC?
Old Feb 11, 2007 | 07:28 AM
KINGxOFxSKA's Avatar
Unique Scionikz
PPC = Private Party Classifieds
Old Feb 11, 2007 | 11:20 PM
bump, theres got to be more out there!
Old Feb 12, 2007 | 04:59 AM
jetlounge's Avatar
stiffy brackets are easy. i did those in my toaster oven.
Old Feb 12, 2007 | 06:23 AM
you know that when you bake an item like that you aren't supposed to use the oven again for food right? Or in your case toaster oven. Also did you and it or just set it in there? Are there marks from where you set it down on? Our goal is the best quality possible, so the less visible marks there are of where we hung it, the better the finished product and the happier the customer is. Some people don't have the equipment to powdercoat, you have to have the proper gun and have to know how to charge the object you are painting so that the paint is attracted and bonded so to speak with the metal. I could go on and on, not saying the way you did it is bad, just stating that there are better ways to do it. Anyone else??
Old Feb 12, 2007 | 01:26 PM
bump it up!
Old Feb 12, 2007 | 04:51 PM
jetlounge's Avatar
i don't remember saying i didn't hang the items...
yeah i have a gun, and the toaster oven is only used for coating small parts, i don't need to do rims for a hobby. you can lay any item flat if the underside won't be seen, and i can hang items from the rack when need be.
charging isn't so hard..clip the item and you are good to go. and charging will simply help you keep the waste down.
charging is not nearly as important as sanding/cleaning/prepping the object thoroughly.
also, you can (though I wouldn't) use an oven for food, if cleaned or if prepped properly. The problem is the mrs. won't like the smell, so my baking is done in the garage.
Old Feb 12, 2007 | 09:16 PM
timfiredog's Avatar
remember, you can not PC plastic parts, only alloys.
Old Feb 12, 2007 | 11:10 PM
I never said you didn't hang it... the hole point of hanging an item in the oven is to hang the item where the marks would be the least visible. Yes you can set it down if that side isn't going to be seen but at the same time I would like the most of my object covered to protect it from the rest of the elements it could be exposed to. I also never said that you didn't have the proper equipment, I was just stating that from the information you gave i.e. just using a toaster oven didn't sound quite right. Charging the item attracts the paint so yes it would keep the waist down but also powdercoating is much more durable than just painting an object.
Our prepping will mostly consist of sand-blasting, which is much easier than sanding an object and if it is needed we can go over any missed areas.
I never said you couldn't eat out of there, but I know I wouldn't. Yes it smells but have you ever thought if the fumes could get into your food? I suppose after a very thorough cleaning that may not happen but that still isn't something I want to do
timfiredog: yes I know you cannot powdercoat plastic parts, although it would be interesting to see what the end result would be after you baked it :D (plus you wouldn't be able to charge the piece either)
Now back on topic, is anyone else interested in this? I know I don't have many details up yet but any feedback is great, so whether it is for your scion or not, let us know what you have in mind!
Old Feb 13, 2007 | 12:40 AM
tC-Collin's Avatar
Scion Tuners
i might be intersted, price pending
Old Feb 13, 2007 | 01:44 AM
what are you interested in getting done and what price do you expect a price... we want to have one of the lowest if not the lowest available price on the market and yet still have great quality. This weekend or next I should be doing my valve cover Black or black sand pearl (not the plastic one ) and I will get pictures posted of it to show off the quality.
Everyone just shout out what you would like to be done and a price that seems reasonable to you and we will go from there.
Old Feb 13, 2007 | 02:02 AM
tC-Collin's Avatar
Scion Tuners
im not quite sure yet, ill use my imagination though
Old Feb 13, 2007 | 02:18 AM
if its metal then throw it at us, I am sure we could do something with it...
Old Feb 13, 2007 | 05:14 PM
We will be doing a set of wheels this weekend and I will post pictures of the finished product.
Old Feb 14, 2007 | 02:25 PM
tC-Collin's Avatar
Scion Tuners
im thinking about my lightweight pulley powdercoated black so it looks stock
elwaylite
9
May 15, 2020 07:27 PM
gedster314
14
Nov 17, 2018 02:56 PM
brett561tc
Sep 15, 2015 06:33 AM
carid
Scion tC 2G Aero & Exterior
Sep 1, 2015 09:08 PM
formerpraetorian
Jul 22, 2015 01:05 AM
