Anyone go with a Test pipe on the Xa yet? also a couple ?'s
Hey i was just wondering if anyone had taken their cat of and replaced it with a Test Pipe yet, or maybe you installed a Hi-Flow Cat. Either way plz let me know what you think of the results.
Also, I have the DC Sports Header and Exhaust, i wanted to know if there was any way i could beef up my exhaust without compromising what little power gainsi have....maybe make it into a straight 3 inch.
Replys plz....need feedback
someone here on the forums put a custom cat-back in their xA during the summer, do a search.... in my opinion it sounded terrible since it sounded WAY too loud for a small car like ours
from what i have seen on the dyno.. your setup is fine for NA application. I'm willing to bet if u get rid of the cat, or increase the pipeing diameter any more, that you will loose power and torque.
Just 2 weeks ago i witnessed this. An xB with lightweight crank pulley, intake, header, and full custom exhaust with high-flow cat put down 2 less hp then a stock xB dyno'd just an hour earlier. I also saw a tC with a full Megan race exhaust (no cat) and intake put down 15 less hp then a stock tC dyno'd the same day. And the torque curve was all jacked up. (Sorry Ken if u read this,
). Unless u run boost, be carful with exhaust upgrades.
i want to make an update/correction on a post. .......
The Tc i just mentioned with the full exhaust just got re-dyno'd on the same dyno (dyno was acting funny that day) and put down 144whp 130 was stock. the xB info is still accurate though.
hey thanks for the advice guys...it seems like ive got Dont's on this subject than do's, on and off the forum. Well thats still cool...i roll up to orlando to Install my rims and springs this weekend..
17 inch BSA #333
D4210 Tanabe lowering springs
205/40/17zrWanali
17 inch BSA #333
205/40/17zrWanali
Guest
Posts: n/a
I recomend not removing the cat as well, the first system that we made was for someone that wanted no cat and he ended losing HP and his gas milage went in the crapper. The VVTI tries to over compensate for the no cat and the check engine light comes on.
spawnconnery
Dec 18, 2014 08:38 PM
