wiring help ...
Old Feb 16, 2007 | 01:17 AM
gicode0823's Avatar
Default wiring help ...
i found the grommet
but i dont know how to put the wire go thru...
how do i do it ....
Old Feb 16, 2007 | 02:40 AM
sddykstr's Avatar
Fit it through the hole or make a slice in it and slide it through. I assume you're talking about the grommet in the firewall.
Old Feb 16, 2007 | 02:47 AM
gicode0823's Avatar
so u cut it ??
Old Feb 16, 2007 | 06:15 PM
nodsetse's Avatar
Drill a hole through the rubber, big enough for the wire, without hitting the metal. Or you can try to cut a slit and wedge it through, although that's not as clean, imo. Of course you could also route wire under the car and drill a hole wherever you want to enter the car, using a grommet there so the wire is protected.
Old Feb 16, 2007 | 06:19 PM
Runawayrogue's Avatar
A more non-intrusive way is to take a wire hangar and feed it through the hole, then tape your wire good and tight and pull it back through. That's worked for me in the past.
Old Feb 16, 2007 | 06:24 PM
SquallLHeart's Avatar
i do a combination... slit hole... feed coat hanger or something else.. and feed it thru
pjl52
Aug 13, 2015 02:38 PM
Wrencher
Jul 29, 2015 01:38 PM
semlin
Jul 29, 2015 02:07 AM
Bish80
Jul 24, 2015 02:02 AM
Mpwr
Jul 17, 2015 08:39 AM
