View Full Version : Help Installing DC Strut bar
salomon003
02-17-2007, 01:04 PM
Well i have followed all the directions but i cannot get the inner nut off...I have the car jacked up and nothing...I cannot get that little nut off, if any one could share ideas it would be appreciated!
KINGxOFxSKA
02-17-2007, 02:05 PM
are you talking about the one on the drivers side?
Dr_Isotope
02-17-2007, 03:29 PM
You have to loosen al three bolts so the strut can slip down about 1/4". You really only need to get the driver's side front wheel off of the ground.
Spect2K3
02-17-2007, 04:01 PM
You took off the wiper cowl for easy access, correct?
tc-guy
02-17-2007, 11:47 PM
it a byotch to do, but take the top black cover off. first u need to take off the wiper blades. use a flathead and pop the cover on the wiper off the un-do the bolts for both wipers.
then use a phillips and poke the middle of all the tabs holding on the black cover. when u poke the middle of the tabs they should come out. after u take off the black cover u have access to all of the strut bolts so it won't be such a pain. u shouldn't have to jack up the car to install the strut bar. hope this helps
Tcguy85
02-17-2007, 11:53 PM
you do not have to remove the wiper cowl thing. just loosen(not take off completely) the last strut nut and the strut will move down enough to get the strut bar on. i had mine on in under 5 minutes. it's easy once you loosen that last nut. oh and you should and have to jack the front of the car up off the ground.
chuynh207
02-18-2007, 12:00 AM
yep.. u dont got to take off the cowl.. just losen it... nd i still dont know y u gotta jack up the car?? i didnt jack up mine?? does it help to jack up the car??
Tcguy85
02-18-2007, 12:31 AM
people say the strut bar does nothing unless you install it with the front tires off the ground. i get the idea of why but not sure how to explain it. but it's easy to jack the front end up so do it.
salomon003
02-18-2007, 12:39 AM
well i finally got it, it was a pain in the ___ though...Thx for all the replys!
Thanks,
Brandon
INFINI
01-03-2008, 10:11 PM
well i finally got it, it was a pain in the butt though...Thx for all the replys!
Thanks,
Brandon
Sup :) Glad you got it done. Can you explain how you did it??
BrEaK_AwaY
01-04-2008, 12:42 PM
it doesnt matter if you lift it off the ground or not. its still gonna do second to nothing. our strut towers are extremely close to the firewall. unless you have a 3 point strut bar ( which to know knowledge isnt manufactured for the tC) its all for show.
INFINI
01-04-2008, 04:42 PM
Yeah mine made a big difference but I have an xA :) and use the TRD strut.
BrEaK_AwaY
01-04-2008, 09:31 PM
i highly doubt it.
INFINI
01-04-2008, 09:35 PM
i highly doubt it.
In my own "personal experience" with the TRD Strut I was much happier with the way the car drove around corners and such than with the Tanabe Strut Bar (that did nothing).
PakanaHerruus
01-04-2008, 09:39 PM
i highly doubt it.
it made a difference on mine with the xb.. with the hotchkis, (not a big difference).. also have their springs.. and soon sway bars..
when i put mine on.. jacking the car up made installation a breeze.. was able to apply pressure on the tire, (which lowered the studs) so i had enough room to put both the strut tower and the nuts..
INFINI
01-05-2008, 12:42 AM
i highly doubt it.
Just to be clear I was not talking "big difference" like putting in Bags or a turbo. But a big difference compared to the Tanabe Strut. I already had a 2.5 drop and Progress Sway Bar.
thekevin
01-08-2008, 02:46 PM
i noticed a slight difference in cornering with my DC front strut bar.
