greddy pipe
im wondering if anyone has had any problem with the evo 2 sliding around and melting the rear lip i cannot keep mine in one place ive tried several things does anyone have this problem or a fix?
Music City Scions
Check to make sure the connection coupler is tight. You may need to add some worm clamps to the rear mount to keep it from shifting side to side in the rubber mount. I was worried about my Strup doing that same thing but because I used a new clamp and gasket it is staying perfectly centered in the hole. Good luck and keep us posted of any fix?
Mine burnt my rear lip but it's not noticeable. What I did was take two industrial zip ties and ran them through the rubber hanger. One going left, one going right. to metal parts of the underbody. Tighten em up and it won't move at all.
Music City Scions
Did you make sure the clamp was tight? That is what helps keep it from moving side to side. On mine I have about a 3/4 inch gap all the way around the tip.
I just installed mine maybe 2 weeks ago and I did it in my garage. I have not had it move once. I had my wife hold it in the exact spot I wanted and then I tightened it at the clamp. I then made sure it was not able to move to much and have been keeping an eye on it. Make sure you have that gasket ring thing in between the pipe fittings and tighten it down real good while someone holds it in place for you. I hope this helps. I can take pics if you want, although I only have a phone camera so no guarantees on the pic quality.
Music City Scions
On mine, my old gasket was shot. It came un wound and was not going to work plus I wanted a new looking clamp so I ordered both pieces long before I did the install. You might want to check and see if your gasket was reusable. That may be why it is moving around.
LOL mine did the same but luckily the Greddy came with a new one that seemed way better, so it was all good.
where the stock pipe and the new axle back come together. The evo pipe goes over the stock on basically. In between there is where the gasket goes, so then when you clamp it down it holds it in there nice and tight. I was wondering why so many people were having problems with their axle backs moving on them. Maybe they too didn't realize that goes in there. My Evo2 has been on for a couple of weeks and not once has it moved from the exact (naked eye measurement) center of the exhaust cutout.
Well you can get a new one from the stealership, or you can try and contact Greddy and see if they will send you one. Here is the number and also email:
(949) 588-8300 M-F 9-5 PST
store@greddy.com
store@greddy.com
Originally Posted by iheartzombies
Thanks bro appreciate it. I cant believe I looked at that thing, said "huh" and threw it away.
Also, I'm safe from flippin' up the car right? The gasket is just for fitment?
Music City Scions
I wonder if the gasket from greddy is better than the OE one? The one from the dealer was under ten bucks I think. Glad we helped ya figure out whats wrong tho iheartzombies.
yeah i got all that tight but only moves if the hanger gets wet i have tried a few things but im sure ill figure something out its starting to get nice out so i may go pick it up ffrom storage and clean it and try to fix that
thanks all
thanks all
SloTC1
Aug 16, 2018 02:45 PM
CrowJenkins
Oct 9, 2015 10:47 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
