help with stock HU, want to add aftermarket sub(s)
guys, i tried searching, but came up with like 20 pages of hits... what do i need to do to add a sub to my current setup. I want to keep the stock head unit, and speakers, and just add 1 10" sub. Is there a particular cable I need to use?
I guess what I mean is, how would they of hooked up the other bazooka sub (factory)?? I want to do the same thing, but not use their sub.
I have a amp, and the wires and all, but before i get started, I figured id try to collect a little more info.
and before someone yells "search" I tried that, see how many hits you get that dont cover what im talkin about!
Thanks in advance!!
Thanks in advance!!
Try this it is plug-n-play i am gonna order one for when i put in my amp and subs in the spring http://www.yoursciontc.com/forums/in...showtopic=5506
As an alternative to the LOCs already mentioned, you could get an amp that has speaker-level inputs, and simple connect in paralell with the stock speakers. REM can be taken from many places, and wire that has +12v when key is in acc position will work, such as the cigarette lighter wire, which is really easy to get to.
yeah i think im gona go stealth and do the nine.2 and a the SQ10 probably this summer. im not to good with audio stuff so most likely ill just get the plug n play so that way once i do get a new HU everything will be set.
kleecker
Scion xB 2nd-Gen Wheel & Tire
May 22, 2016 06:10 AM
TheTripleC
Jan 4, 2015 06:46 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
