tC Wiperblades "Drag" Along Windshield
Old Feb 21, 2007 | 06:03 PM
pixelinpink's Avatar
Default tC Wiperblades "Drag" Along Windshield
Anybody's tC wiperblades "drag" along the windshield? Mine leave rubber tread marks and squeak loudly when they're in use, no matter what the precipitation. I've tried different brands but I still have the same problem.
Old Feb 21, 2007 | 06:07 PM
captainlaziness's Avatar
Maybe try waxin' your windsheild.
Old Feb 21, 2007 | 06:10 PM
Still results in the same problem.
Old Feb 21, 2007 | 06:13 PM
I dunno. Have you tried Rain-x?
Old Feb 21, 2007 | 06:28 PM
BuddhasTC's Avatar
adjust the actual wipers...maybe they're too tight
Old Feb 21, 2007 | 06:30 PM
^^You can adjust the wipers? How?
Old Feb 21, 2007 | 06:32 PM
Yes, how??
Old Feb 21, 2007 | 06:33 PM
tCTaco's Avatar
Yeah...mine moved on me...I had to adjust them and I made them to tight and they did the same thing
Just losen the bolt that attaches the wiper to the car. Remove the cap and there is a nut under it. Just barely turn it until it dosent rub so hard
Old Feb 21, 2007 | 06:40 PM
I'll hold my comments so as not to get this thread locked Taco. :D
Old Feb 21, 2007 | 06:43 PM
tCTaco's Avatar
Yeah...wouldnt want the wiper to rub hard with the nuts to tight
Old Feb 21, 2007 | 06:56 PM
Scott8's Avatar
this is going down the toilet fast!!!!
Old Feb 21, 2007 | 07:07 PM
paul34's Avatar
maybe your wipers are worn out, or the rubber has degraded. Also, your wipers might be dirty... they should be well cleaned at every wash or at least once every two weeks.
Old Feb 21, 2007 | 11:53 PM
Hyghgynx's Avatar
I replaced mine with the Rain-X wipers. (YES! They do work.) Only $25 at Pep Boys. They were out of one of the sizes of wipers I originally wanted () so I decided to try the Rain-X wipers. Picked these up and they work great!
Old Feb 21, 2007 | 11:58 PM
draxcaliber's Avatar
i kinda have the oppossite problem, my little wiper seems to do almost nothing, maybe i'll see if i can tighten it...
Old Feb 22, 2007 | 01:50 AM
FLINT's Avatar
going down on hard rubbing tight nuts that leave streeeeeks
Old Feb 22, 2007 | 01:53 AM
Scott8's Avatar
Old Feb 22, 2007 | 08:09 AM
Those the ones that leave a layer of Rain-X with every pass?
Old Feb 22, 2007 | 11:46 AM
sciontc_mich's Avatar
Default Re: tC Wiperblades "Drag" Along Windshield
I doubt putting more coatings on the windshield is going to help at this point.
What I suggest (As well as a tsb from toyota says the same thing) is to clean the windshield with a cleanser you can get at the grocery store called BON-AMI. It is a safe abrasive to use for glass and WILL NOT scratch glass. just make sure to use it with water, and scrub the windshield, then rinse. Your "skipping" of the blades should be gone after that.
I've noticed that the tC builds up residue quicker than other cars, might have something to do with the angle (it's a steeply inclined windshield). I have used BON-AMI on many cars and it does a great job of getting rid of grime and stuff that cause wiper blades to chatter and streak.
Let us know how it goes, I bet the problem goes away after you clean it with bon-ami. Also - Look into Bosch ICON wiper blades, great stuff, much better quality than I've seen from other manufacturers. But cleaning the surface will help the most!
Old Feb 22, 2007 | 02:55 PM
Scott8's Avatar
So nothing to do with his tight nuts then....
Old Feb 22, 2007 | 05:59 PM
^^Heh heh. :D
