Paint Chips.. HELP!
Old Feb 26, 2007 | 06:22 PM
ForceNut's Avatar
Default Paint Chips.. HELP!
I am not sure if this is the right place to post this...
BUT I got my car washed the other day and I noticed a deep paint chip in my drivers side door... It looks like the paint around the chip might start to come off as well.. I want to stop this problem and fix it up. Will buying the touch up paint from the dealer help me out or make it worse?? I obviously don't want to get the whole thing professionally painted just for this one chip, but I am afraid that if I leave it it will get worse.
Dealer touch up paint... good or bad??
Old Feb 26, 2007 | 07:06 PM
Daurigon's Avatar
if you get the touch up paint, then you will have to apply it and use a buffer to make it look nice. dont pick at it and you should be fine.
Old Feb 26, 2007 | 07:08 PM
ForceNut's Avatar
What about this kind of thing??
http://www.expresspaint.com/
Old Feb 26, 2007 | 07:15 PM
Ty_Max's Avatar
paintscratch.com might work to?
Old Feb 26, 2007 | 08:11 PM
ForceNut's Avatar
paintscratch.com seems way more expensive...
anyone use anything like this and have a good experience?
Old Feb 27, 2007 | 06:03 AM
gomdangie's Avatar
just a little tip from my experience...
when you use dealer touch up paint, make sure u shake it for long time for paint to mix otherwise color will be different.
and also if the chip is small, take time to do it, use toothpick or something, don't use the brush that it comes with.
this won't look perfect, but it might prevent from coming off
Old Mar 3, 2007 | 06:52 PM
BlueTC06's Avatar
You should get the dealers paint its like 9 bucks, clean the surface, apply a little bit on the chip, let it dry, add another after that drys and then add a clear coat on top of that. make sure you add like 3-4 coats of clear, then when wait a day for it to dry, pick up some wet sand paper 1500-2000 grit, (Meguiars works best) Then clean the surface free from dirt and grease. Wet sand the area to the point were the shine is gone. DON'T sand past the clear. Then get some compound and buff the area until it has a rich color to it. Then get some polish and buff over that until u get a shine. After that you can get some glaze polish and apply it by hand so you get a clean polished OEM look
jeremydoc
Sep 16, 2015 11:31 PM
yoson13
Scion xA Aero & Exterior
Aug 30, 2015 07:38 PM
WVXC450R
Scion tC 2G ICE & Interior
Aug 26, 2015 03:15 AM
10spokess
Aug 16, 2015 02:50 AM
mc1114
Scion tC 1G Aero & Exterior
Aug 10, 2015 10:34 AM
