Cambering and alignment shops
Old Feb 26, 2007 | 09:33 PM
tarman's Avatar
Default Cambering and alignment shops
Yo. When the weather turns a touch warm, I'm switching out my TRD springs for DF210s and monroe's. I'll need to get an alignment after all is said and done.
I'm debating setting myself up with some camber - OTG in the rear, maybe some camber bolts for the front for a degree or two. My question is, the toe out needs to be set to minimize tire wear. I know the OTG shims have it built in, and the front does not. Therefore, I'll need to get the front adjusted at a shop. Won't they look at my wheels and say, "that camber is off, need to adjust that" or something? If I tell them to leave the camber alone, will they know how much toe to compensate?
Sorry if this is a stupid question. Let me know if that makes any sense at all. Thanks!
KJ
Old Feb 26, 2007 | 10:17 PM
hotbox05's Avatar
you can tell them you want to keep teh camber as is . or say 1 degree , or 2 degree and that you want the toe corrected as much as possible without removing the camber.
Old Feb 26, 2007 | 10:22 PM
streetlethalxb's Avatar
yeah, the toe can be set, regardless of camber... toe will change slightly with changes in camber and vise versa, but either can be change regardless of the other (independently).
Old Feb 27, 2007 | 04:35 AM
Boxer_Rebellion's Avatar
OTG shims are supposed to have built-in toe correction
Bmfxtreme
Aug 18, 2015 01:25 AM
domincnTC
Aug 4, 2015 01:47 PM
Subaru86
Jul 31, 2015 04:33 AM
sgetchius143
Jul 28, 2015 09:55 PM
TOOSLOW
Jul 25, 2015 05:19 PM
