Nick
08-24-2004, 09:05 PM
Just wondering if anyone else has them installed. Does the rear sit lower than the front. Cause mine does. Thanks Nick
View Full Version : Hotchkis Coils Problem!! Nick 08-24-2004, 09:05 PM Just wondering if anyone else has them installed. Does the rear sit lower than the front. Cause mine does. Thanks Nick xBMNx 08-24-2004, 10:46 PM as far as i know there suppose to....the front is a 1.5 to 1.6 in the front and 1.7 to 1.8 in the rear DGTLLVR 08-29-2004, 05:17 AM Well it should sit level. When you installed them you might not have sat the springs on the struts properly, I would check it out. Is it making any noise when driving, cornering, or going over bumps? JdMBboFSD 08-29-2004, 05:29 AM Well it should sit level. When you installed them you might not have sat the springs on the struts properly, I would check it out. Is it making any noise when driving, cornering, or going over bumps? agreed.......check that ....... 08-29-2004, 06:15 AM the first generation of Eibach springs were like that. The front was higher than the rear, so you this is sometimes normal. Might want to move to another brand of spring if your not satisfied. brownbanana 08-29-2004, 07:53 AM i know the hotchkis springs for the 03+ corollas had the higher drop in the rear than the front. neckbonenick 08-30-2004, 03:15 AM I'll be installing some on my box this thursday. and I'll let you know how it goes. neckbonenick 09-03-2004, 01:49 AM got the rears installed today, before i ran out of sunlight. My work is closed for the hurricane tomorrow so I will let you know how it looks then. I think I will make a separate post for Hotchkis springs installed. neckbonenick 09-05-2004, 03:12 PM I installed the fronts on Monday and made a new post http://www.scionlife.com/forums/viewtopic.php?t=26347 WileECoyote 09-10-2004, 10:41 PM my hotchkis springs fit well, and are level. They drop more in the rear because it sits higher in the first place. |
