emblem glue
Old Mar 3, 2007 | 05:30 PM
himynameischris's Avatar
Default emblem glue
whats the stuff they use to put the tc emblem and other emblems on cars.
and can you buy this at a walmart or supermarket?
Old Mar 3, 2007 | 05:41 PM
STNC's Avatar
3M Tape i think, usually it comes on the back of the emblem, you just pull it off and stick it.
Old Mar 3, 2007 | 06:58 PM
TeeCizzle's Avatar
3M double-suded tape...at any Auto Parts Store
Old Mar 3, 2007 | 07:05 PM
jwaggz82's Avatar
They key is using "outdoor" double sided tape. That tape holds a ton better. For my grille I cut out pieces of it and put it under the emblem. Then I put 2-3 drops of superglue on (very very small drops - im not even sure of that did anything). I haven't had any problems for over a year. The one thing is ...make sure its strait and exactly where you want it. Mark it up so you do it right the first time. Back off the car 10-15feet and look how it looks. When you are happen then worry about mounting it for good. The last thing you want is a tilted off-centered emblem.
Old Mar 4, 2007 | 04:03 AM
thanks guys...
Old Mar 4, 2007 | 04:30 AM
jwaggz82's Avatar
np
Old Mar 6, 2007 | 03:49 PM
daxII's Avatar
One thing I've found that works great for emblems is JB Weld. It's a two part epoxy that comes in a small package. You should be able to pick it up at Home Depot or your local auto parts place. This is of course if you don't ever want the emblem removed ever again! I'd definitely keep with 3M tape if your emblem is going to be temporary. JB Weld is nice though because you can apply it, and then center your object accordingly before the epoxy completely sets up. Just don't use too much of it or it'll "squish" outside of the area of application. I used it for my back emblem and CF emblem insert. Those suckers are not going anywhere.
StxArOne
Scion xA Aero & Exterior
Apr 3, 2018 02:22 PM
ScionDP
Scion tC 2G ICE & Interior
Nov 5, 2015 09:59 AM
StxArOne
Aug 29, 2015 03:29 PM
sciongirl13
Jul 22, 2015 02:28 AM
Max2k
Oct 13, 2004 03:01 AM
