View Full Version : STRAIGHT PIPE!!
scion_mannnnn
03-04-2007, 08:54 AM
anyone ever try this? im thinking it would be an easy diy mod and it would gain some hp. also, would anyone know if it would pass emission? if this aint a good idea, what kind of aftermarket exhaust would be recommened?
streetlethalxb
03-04-2007, 12:45 PM
I've straight piped every car 've owned, except the box. I used a Tenrai axle back, its
quiet. But I dont see a problem with one, as long as your cat is still there. Noise
laws? Good luck!
scion_mannnnn
03-04-2007, 06:06 PM
you notice any hp gained after adding the exhuast?
scion_mannnnn
03-04-2007, 06:07 PM
jsa3mm
03-04-2007, 06:12 PM
If you cut off your catalytic converter you will not pass emissions. Also, if you do decide to take off your catalytic converter you will need an 02 Simulator to keep from throwing CELs.
streetlethalxb
03-04-2007, 08:37 PM
on my V8's it was a huge gain
guitarguru44
03-04-2007, 08:45 PM
it will definitely be a gain.. its better than having a headerback exhaust i guess.. only problem would be the noise and you might lose some torque..
wanachat15
03-05-2007, 12:18 AM
http://i8.photobucket.com/albums/a19/tomandclever/DSC02555.jpg
just a little louder. love the deep noise and no torqe lost. actually gained which is causing a lot of cluth slip and not beacuse my clutch is old.
ma thread: http://www.scionlife.com/forums/viewtopic.php?t=164595&highlight=
--tom
scion_mannnnn
03-05-2007, 06:04 AM
how did you connect the pipping? any welding? bolt on?
wanachat15
03-05-2007, 06:53 AM
for the test pipe where the cat was i just bolted it on. and for the piping i had to cut off the stock exhaust pipe (the flang side, inlet not outlet). so i welded that part to a 2 1/4" that i had a exhaust shop bend for me. i bought a stainless steel tip and tacked that on to the pipe. so it's the same as the bolt on axel back, but instead of an exhaust. it's a pipe with a tip. i wanted a jdm look so i had it at a up ward-right angle and sticking out about 3 inches from the bumper.
---tom
scion_mannnnn
03-05-2007, 10:53 PM
wow, thanks for the details. ill be sure to post my exhaust when im done. :clap: :clap:
