quick offset question if you don't mind...
Old Mar 5, 2007 | 03:43 AM
iamamachine_ist's Avatar
Default quick offset question if you don't mind...
i think i'm gonna go with enkei rs-7 18" with 225/40s. i was wondering what offset will look better and allow me the most drop when i do drop. 35 or 45.
thanks so much for any input.
(i did search by the way but i couldn't find the exact answer i was looking for. sry)
Old Mar 5, 2007 | 04:53 AM
MPanova's Avatar
Old Mar 5, 2007 | 08:38 PM
Hat_Trick_Hokie's Avatar
45mm is the stock offset, so 35 would normally stick out nicer. What is the width of the wheel you're putting the 225 wide tire on? This could affect if the tire is stretched a lot or not. And what drop are you looking into? You'll need more clearance with the S-Techs then TRDs etc.
Look through the "What Fits" sticky. Skim through it, and your answer might be in there:
https://www.scionlife.com/forums/viewtopic.php?t=101733
Old Mar 5, 2007 | 09:43 PM
the wheels are 7.5" and i'm planning on getting coilovers. so really i'm more concerned with looks. i was thinking 35 i just wasn't sure if 35 was enough offset. i don't want anything rubbing when i do drop it.
i did look thru "what fits" but couldn't find a clear answer.
thanks
scionlife
371
Jun 2, 2015 11:00 PM
TotalChaos
13
Feb 4, 2015 10:24 PM
gettoastedinthetoaster
Scion xB 2nd-Gen Wheel & Tire
Dec 29, 2014 11:39 PM
smilygo
Oct 1, 2003 07:03 AM
Male_Nurse
Sep 27, 2003 10:59 AM
