vvt-i.....HELP!
Old Mar 6, 2007 | 07:44 AM
hansta's Avatar
Default vvt-i.....HELP!
i was just havin a drink with couple of my buddies who also drive a tc,
and we came to an unsolved question about scion tc's engine, not one of us knew
where the tc's engine came from and one of them said they are pretty sure it came from toyota camry and the other one said toyota celica.....can anyone help us!!!!
Old Mar 6, 2007 | 07:46 AM
ahloung's Avatar
its a camry engine but its also the celica GT engine... i think its also on the matrix also
Old Mar 6, 2007 | 07:49 AM
Slow_Racer's Avatar
nope the matrix base and xr was the 1zzfe same with the celica base and GT and the xrs and the celica GTS was a 2zzGE engine.
Old Mar 6, 2007 | 07:51 AM
ahloung's Avatar
Originally Posted by Slow_Racer
nope the matrix base and xr was the 1zzfe same with the celica base and GT and the xrs and the celica GTS was a 2GEfe engine.
the celica base is the GT...
Old Mar 6, 2007 | 07:55 AM
Slow_Racer's Avatar
oops okay my bad.... :D thanks
well the 2azfe was also in the...
rav-4
the solara..yeah its its a camry. so nvm
oh and the highlander
Old Mar 6, 2007 | 07:58 AM
ahloung's Avatar
i just looked it up... the celica GT has the VVT-I engine too... along with the camry..
Old Mar 6, 2007 | 08:00 AM
ahloung's Avatar
the matrix Xr also has it... http://www99.shopping.com/xPR-Toyota...arch.yahoo.com
CarbonXe's Avatar
2AZ-FE
The 2AZ-FE is a 2.4 L (2362 cc) version built in Georgetown, KY. Bore is 88.5 mm and stroke is 96 mm. Output is 157 hp (117 kW) at 5600 RPM with 162 ft·lbf (220 N·m) of torque at 4000 RPM. The 2AZ-FE also has one-piece cast camshafts. Output for the 2007 Toyota Camry is 158hp and 161 lft lbs of torque
Applications:
* Toyota Camry
* Toyota Camry Solara
* Toyota Highlander/Kluger
* Toyota Estima / Toyota Previa / Toyota Tarago
* Toyota Alphard
* Toyota Blade
* Scion tC
The 2007 Toyota RAV4 produces 166 hp (123 kW) at 6000 RPM and 165 ft·lbf of torque at 4000 RPM
*Stolen from Wikipedia.
Old Mar 6, 2007 | 08:02 AM
Slow_Racer's Avatar
yeah it does....well most or all of the toyotas now days have vvt-t or vvtl-i or more recently dvvt-i...(dual vvt-i)...but as for the same engine ours is different...
and dude trust me i had a matrix...
vvti.. all it means its ..Variable Valve Timing with intelligence.
and the vvtl-i is like the oOO so famous V-tec
just a litle tid bit if you wanted to know.. :D
Old Mar 6, 2007 | 08:29 AM
hansta's Avatar
sooooooooo it's camry and~ celica!
Old Mar 6, 2007 | 08:33 AM
CarbonXe's Avatar
No, the engine in the tC (2az-fe) has never been inside the Celica. It just shares the VVT-i, which is in most if not all late model Toyota's.
Old Mar 6, 2007 | 08:51 AM
Slow_Racer's Avatar
yeah what he said....
celica engine (1zz-fe) or (2ZZ-ge)
camry and tc (2az-fe) two different engine codes mean two different engines.
well even the xB and the xA has vvt-i tho it has 1nz-fe.... a smaller engine
Old Mar 6, 2007 | 09:21 AM
sciontc_mich's Avatar
and to add, the 2az-fe that we have is built in Japan, since our car is built in Japan.
Only US-Built cars get the 2az-fe from Kentucky.
Old Mar 6, 2007 | 10:49 AM
CarbonXe's Avatar
Thanks for the add, you should add that onto Wiki
And Happy B-Day to Slow_Racer, you better be going to a strip club tonight!
Old Mar 6, 2007 | 01:19 PM
CuRiOuSfIsH's Avatar
correct me if I'm wrong, but I think the 2AZ-FE is also in the FJ Cruiser.
Old Mar 6, 2007 | 01:26 PM
MeatRocket's Avatar
a 4 cyl fj , nope they are all v6 standard.
Old Mar 6, 2007 | 03:01 PM
Good idea thanks! done!
Old Mar 6, 2007 | 09:06 PM
Old Mar 6, 2007 | 10:32 PM
Slow_Racer's Avatar
the fj has a 1GR-FE v6 and is shared with the Tacoma, Tundra, and 4Runner.
Old Mar 6, 2007 | 10:59 PM
SquallLHeart's Avatar
wow..... just wow @ this thread....
