View Full Version : 07 scion tc radio removal?
o7ScionTC4gg
03-08-2007, 04:46 PM
how do i remove or start so take apart tha console in a 07 scion tc?
scion07
03-08-2007, 05:05 PM
wow, ok just pull on the middle of the dash everything comes out easy couldnt get any easyier then get a phillips head screw driver and i believe there is 2, maybe 4 screws holding a bracket in un do that pull the wires out from the back and there u go
nodsetse
03-08-2007, 06:28 PM
You can look HERE (http://www.scionlife.com/forums/viewtopic.php?t=60981) to see the "How to gut a tC" thread, including how to remove your console. For the HU removal itself, you'll need a phillips screwdriver and a 10mm deep socket, if you have one. It can be done with a 10mm open-end wrench, but it's a bit of a tight area to work in.
SquallLHeart
03-08-2007, 06:31 PM
a regular socket should be deep enough to reach the nut... but depends i guess on the set.
nodsetse
03-08-2007, 06:43 PM
^ Ya it does, because mine weren't deep enough! :(
