spipe midpipe question
Old Mar 9, 2007 | 09:43 PM
allannss's Avatar
Default spipe midpipe question
i searched n i couldnt get a straight answer so here it goes ... i just installed spipe back with oe-rs system .... everything seems fine but wen i revd the engine i hear sum kind of rasp sound .. i dont have a header ... i guess kinda like buzzing ... does that mean theres a leak?
Old Mar 9, 2007 | 10:18 PM
Scott8's Avatar
is the exhaust hitting any part of the car?
Old Mar 10, 2007 | 01:46 AM
caveman's Avatar
1UP Crew
Check ur connection again between the s-pipe and mid pipe...
I installed headers but still have my stock exhaust and I think the noise I get is similar to what you are talkin about....
You might want to try and get some sort of sealant like copper gasket, something like that (I have some in the car if you want the exact name)...and try loosening the mid pipe putting some in there and re tighten it....it should take some of that noise away...
Sorry if this doesnt help at all....lol
Old Mar 11, 2007 | 11:18 PM
davedavetC's Avatar
if you put the stock bar that is held in with 4 bolts on (that is holding stock exhaust up from falling, take it off and the new exhaut wont hit it causing the annoying rattleing sound.
Old Mar 12, 2007 | 06:07 PM
monkeysauce's Avatar
I have the same setup, and luckily don't have any buzzing problem. However, buzzing is often a symptom of an exhaust leak. Get yourself 3 feet of garden hose or similar, put one end in your ear and the other near the different connection points. You should be able to pick out the spot where your leak is.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
xBassist
9
Jan 21, 2004 07:34 PM
