just got my 25 mm spacers
Old Mar 10, 2007 | 08:26 AM
wanachat15's Avatar
Default just got my 25 mm spacers
just got my spacers and here how it looks. has totally no fender gap and has mean rubbage. the fender has been slicing up my tires so tomorrow i will grind out 3/4 of the fender lip and reseal it. also i left the 5mm spacers i already had so it's not 25mm any more but 30mm altogether.
(before)
(after)
(the spring didn't seat properly yet so theres a gap)
see how much rubbage there is, it's pretty low. half way down the tire.
----tom
Old Mar 10, 2007 | 02:29 PM
JSosa's Avatar
thats alot of tire rub...
Old Mar 10, 2007 | 04:55 PM
ROBs-xB's Avatar
dude, PLEASE, GET THAT ROLLED
IT WILL HELP OUT ALOT
Old Mar 10, 2007 | 07:31 PM
Gsnorgathon's Avatar
30mm? Yow. What offset are the wheels you're running? Time for some negative camber, maybe?
Old Mar 10, 2007 | 11:33 PM
kimgt's Avatar
wow that second pic is sig worthy.
Old Mar 11, 2007 | 09:22 AM
wanachat15's Avatar
how do you roll the fender? from all the rubbing. the tire ate up all the paint and rubber lining. so i'm just going to grind the bare metal that's showing and coat it with rust proofing and rubberized bed lining spray.
Old Mar 11, 2007 | 03:44 PM
ROBs-xB's Avatar
there is a tool that you use, but if you dont have access to the tool
then use a base bat bat, just be sure to heat the area with a heatgun
first to prevent the paint from cracking.
If the rubber lining is off, your tires will start to get torn up, just use
a baseball bat u shouldn't have any trouble with cracking, but use
the gun just in case.
Old Mar 12, 2007 | 09:48 PM
wanachat15's Avatar
i know the bat technique but i'm to scared to even try. where can i get the tool? and yea my tire is already torn up. thanks.
-------tom
Old Mar 12, 2007 | 09:55 PM
LeroyJMC's Avatar
I'd strongly urge you not to try any homebrew body work if you don't have experience wanachat15. There is a tool and the baseball bat has been done, but that type of thing is best left to the shops that know what they're doing. You can really make your box look like poopie very easily doing it.
I personally have zero experience doing it and I would not even think about trying it without someone with years and years of experience helping.
Old Mar 12, 2007 | 10:47 PM
burstaneurysm's Avatar
I witnessed the baseball bat technique over the weekend. It worked really well. Anyway, you can have a shop roll them if need be.
Old Mar 13, 2007 | 12:00 AM
_eE_'s Avatar
We used an eastwood fender roller......quick with 2 people and a heat gun.......That is a definite. Don't know where the fender roller is. Munky works in iwalei does it for sbout $130.
ruzzzell
Scion xB 2nd-Gen Wheel & Tire
Oct 11, 2015 04:18 PM
terrye
Sep 26, 2015 12:24 AM
axB
Sep 18, 2015 06:11 AM
reniculous1
Aug 14, 2015 03:16 PM
