shortend my shifter
Friday night i decided to take my dash apart to paint the trim. Then i decided to take the shifter apart and pull it outta the car and take a look at it. I was very board that night. So then i decided after looking at it i was going to shorten it 2 inches. I put it in a vice and took a hacksaw and cut it. Re-threaded the shifter and scred the shift *** back on. now i have a short shifter. Note pic's are from my phone.
picture of it cut and how much i cut off.
pic of the **** screw on
Installed in car
[img]
[/img][/url]
Installed in car
[img]
[/img][/url]
Originally Posted by mike6789k
wow... you realize a "short shifter" isnt just a cut shaft...
your throw is still the same as before... if anything, your shifting is going to be sloppier...
.....pwned
Um the throw is shorter mike. Geometry will show that. Your hand moves less with a shorter shifter.
Now, this isint really a good way to build a real short shifter, but if it works for him then that is fine. A true short shifter moves the pivot point up and shortens the shifter. The reason being is to keep the leverage, shift and length optimal.
In his case, angular movement is the same, while actual distance traveled by the shif **** is lowered.
Originally Posted by tcdrummer
thats a nice read up, is that the ONLY way to do it though??? i don't have access to those sort of things in that read up. thanks
Small set,
http://www.homedepot.com/prel80/HDUS...gjj.0&MID=9876
yes i used a die, thread size was12X 1.5 metric. same as your lug nut thread if that helps. the throw is shorter cause the point at witch it moves is closer to the falcome point like what was said. Alough it dose not take any more effert to shift. I didn't feel like spending money on a shifter plus if it didn't work then i'd have to. also i don't have to worry about it breaking or something coming apart like i hear about aftermarket shifters. By looking at it the most u can cut of would be 2.5 inches and have no prob threading the stock **** back on.after that the shaft gets thicker and then you would have to retap the **** and go to a bigger size die on the shaft. I might think about taking 3/4 inches off the bottom and re welding it. to make it a true short throw shifter.. you can get a tap and die kit at a auto parts store sears lows home depot or other fine retailers that sell tools... they are handy incase you strip a bolt or something or cross thread something.
