xezerax
03-12-2007, 10:13 PM
i have the 3 pulley set and i was wondering if i change the crank pulley back to stock, would i get any negative effects from the underdrive alt. pulley still on? or would it not really effect my charging system
View Full Version : NST pulley question xezerax 03-12-2007, 10:13 PM i have the 3 pulley set and i was wondering if i change the crank pulley back to stock, would i get any negative effects from the underdrive alt. pulley still on? or would it not really effect my charging system draxcaliber 03-12-2007, 10:30 PM there isn't an underdrive alternator pulley, it is an overdrive pulley. the potential negative side-effect is that you could burn out your alternator. BuddhasTC 03-12-2007, 10:39 PM http://www.yoursciontc.com/forums/index.php?showtopic=6923&st=0 Info on pulleys maybe this has something to help you with any questions redwar1441 03-12-2007, 10:56 PM yu should be fine, in fact better off without the nst crank. Im not a suporter of aftermarket non dampened pullies. :no: :nope: xezerax 03-12-2007, 11:01 PM yea woops overdrive alt pulley. damn i didnt wanna have to pull the alternater again. redwar1441 03-12-2007, 11:16 PM why its not that bad! :P 3min3m2 03-12-2007, 11:24 PM in theory you could burn out the alternator...i dont know enough about them, but its hard to tell hPower 03-13-2007, 01:42 AM You should ask the experts who built your pulleys! AIM screen name NSTonAIM. You can use their overdrive alternator pulley and the water pump pulley with a stock sized crank pulley and you will not have any problems. There are a lot of people around here doing that. |
