Zero Point turbo kit installed, tuned, and dynoed.... (PICS)
Old Mar 13, 2007 | 08:25 AM
WA2GOOD's Avatar
Default Zero Point turbo kit installed, tuned, and dynoed.... (PICS)
We just completed a Zero Point stage 1 turbo kit install on "prettystandard's" Tc.
The kit wasn't the best fitting or most well crafted kit I have seen, but i have seen worse.
To make a rather long story short....after some (IMO, much needed) improvements were made to the kit, it went on fine (kinda) and the car was ready to tune, and then fine tune on the dyno.
The results were a respectable 258.0 FWHP. with only 7PSI (in 90 degree weather)
Here is the dyno sheet.....
Old Mar 13, 2007 | 12:43 PM
318_tC's Avatar
What was so bad about it?
Nice #'s! Congrats on boost!
Old Mar 13, 2007 | 01:59 PM
MrScion07's Avatar
^ yeah plz do tell about what was so bad about the install
Old Mar 13, 2007 | 02:03 PM
TCpete's Avatar
watching.. #s look good though! weres your a/f at?
Old Mar 13, 2007 | 03:00 PM
cessblood's Avatar
+1
Old Mar 13, 2007 | 03:03 PM
Whocares05050's Avatar
Pics of the completed kit? and the A/F 's?
Old Mar 13, 2007 | 03:25 PM
Also, What " Modifications " or " improvements " did you have to do to the kit?
Old Mar 13, 2007 | 05:23 PM
jwaggz82's Avatar
Those are some darn nice numbers. Good job!
Old Mar 13, 2007 | 06:45 PM
WA2GOOD's Avatar
Nothing was that bad, the kit had some fittment issues, the pipeing was not bead rolled, thus causing the couplers to blow off under boost alot easier than they should. I also do not prefer the dump tube method, and would rather have the blown off gasses directed back into the exhaust for eficiency reasons. (it makes it sound better too, IMO)
So after we had a couple blown off tubes, we uninstalled the tubeing and bead rolled it the way it should have been done in the first place, and re-routed the dump tube back into the exhaust.
Eventually the kit worked out fine. The fit and finish wasn't what I hoped it would be, but all's well that ends well.
Old Mar 13, 2007 | 07:02 PM
318_tC's Avatar
The customer might have opted for open dump?
Bead Rolled piping FTW
Old Mar 13, 2007 | 07:47 PM
WA2GOOD's Avatar
I discussed the pros (if there is any) and cons of open dump systems to the customer, and it is my understanding that ZPI doesnt even give you a non-dump option.
And yeah....the kit should have had the bead rolled tubes to start with.
Old Mar 13, 2007 | 07:49 PM
bcnu_702's Avatar
WA2GOOD, I am sure I share this same sentiment with a lot of scion owners, but I really appreciate the work of installing, dynoing, and providing your professional opinions on different turbo kits available for scions. Great work and keep it coming!
Old Mar 13, 2007 | 07:51 PM
AndrewGene's Avatar
Sorry for the stupid question but what is a "bead rolled" tube?? Is there a before and after picture i could see or something???
Old Mar 13, 2007 | 08:39 PM
You dont need bead rolled pipes. the couplers they use are pretty good. I for one have had a ZPI kit for a month and havnt had a coupler blow off yet.
Old Mar 13, 2007 | 08:41 PM
OuterHeaven's Avatar
ZPI used to offer a non-dump down pipe but I thought you had to ask for it specifically?? (Here is an example... The pic is pretty far down the post https://www.scionlife.com/forums/viewtopic.php?t=103104) The reason ZPI says they do not do it because they said they dyno'd like 20 more HP with an open dump. It sucks that they no longer bead roll their IC piping. On my stage 0 pipe it is bead rolled (and it even looked nice) but I do not know why they stopped. Though I have the same IC piping I have not had any issues with piping coming off at all but I took my time with installation and all couplers were installed very carefully.
Old Mar 13, 2007 | 08:44 PM
redwar1441's Avatar
bead rolled is not neccisary. I work on diesels running 25 psi through 3.25 inch pipe that is not bead rolled with silicon couplers and t bolt clamps and ive never ever seen a pipe blow off that was installed correctly.
Old Mar 13, 2007 | 09:19 PM
Kumitsu's Avatar
anybody knows ?
Old Mar 13, 2007 | 09:27 PM
Simplyscion's Avatar
Team No Limitz
check the lip around the end of the pipe
Old Mar 14, 2007 | 12:24 AM
rhythmnsmoke's Avatar
Music City Scions
Those are some damn good #'s for 7lbs of boost. I don't think my pipes are Bead rolled either, but then again, ZPI themselves hand made our kit to my specs.
But glad to see you guys got everything worked out. Nice job.
Old Mar 14, 2007 | 12:34 AM
Music City Scions
So, where specifically did you have fitment issues?
