Sub Wiring
Old Mar 14, 2007 | 06:46 PM
Zsanz's Avatar
Default Sub Wiring
Hey i couldent find anything under the search topic about this i was just wondering if i can wire a 500w Rockford amp to a 1600watt lanzer amp for a total of 2100watts then put that into two subwoofers..is it possible to wire two amps together and have more power even if their of different brand names. thankyou in advance.
Old Mar 14, 2007 | 08:13 PM
nodsetse's Avatar
That depends on what you mean by "wire to", how you're proposing to connect them together.
Connecting both to the same power distribution block is fine.
Attempting to bridge (or more correctly, "strap") them together to produce a single output won't work. To do that, get two identical amps of the same brand and model which are designed to be implemented that way. I think this is the answer to what you were specifically asking, so "no".
If you're just talking about using one amp for 1 sub, and the other amp for another sub, that can be made to work, but it'll take some effort. Both subs need to be the same, and the amp gains will need to be set so that each sub is getting the same amount of power from whichever amp is feeding it.
Old Mar 14, 2007 | 10:37 PM
Zebman's Avatar
You're out of luck. Depending on what subs you have, 1200watts into both may be enough.
Old Mar 15, 2007 | 02:27 AM
Zsanz's Avatar
whell I got two kicker l7s tonight and I put em in the back of my camry wired up too a 1600watt amp...its INSANE. soo I don't think ill be needing the extra 500watts anyway..thanks for the help
Old Mar 15, 2007 | 02:42 AM
Zebman's Avatar
I don't know where I got 1200, haha.
Old Mar 15, 2007 | 07:10 PM
nodsetse's Avatar
I agree, 1600w is more than than enough for any sane person, imo.
Old Mar 15, 2007 | 07:32 PM
Zsanz's Avatar
But is their such thing as too much bass?
Old Mar 15, 2007 | 08:12 PM
nodsetse's Avatar
^ I can't answer that.
I could answer the question "But is there such a thing as too much bass?", however, that's not what you asked.
Old Mar 15, 2007 | 08:15 PM
Neothin's Avatar
bah, technicalities ^^
Old Mar 16, 2007 | 02:11 AM
Zsanz's Avatar
blah blah same difference
Old Mar 16, 2007 | 11:53 PM
Zsanz's Avatar
http://img409.imageshack.us/my.php?i...1607001hb4.jpg
Old Mar 16, 2007 | 11:56 PM
Zsanz's Avatar
Rob54Monty
Feb 3, 2023 08:26 PM
RokGoblin
Scion tC 1G ICE & Interior
Aug 11, 2015 05:24 PM
domincnTC
Aug 4, 2015 01:47 PM
Wrencher
Jul 29, 2015 01:38 PM
semlin
Jul 29, 2015 02:07 AM
