Serious question...NEED HELP PLEASE!!!!!!
Old Mar 19, 2007 | 02:20 AM
XB_XIII's Avatar
Default Serious question...NEED HELP PLEASE!!!!!!
my 06 xb will not shift into overdrive until my cool temp light has gone off..as soon as the blue light goes off it shift to the final gear...no check engines lights are on.. just wondering if anyone has an idea....please help
Old Mar 19, 2007 | 02:43 AM
screamnchikn's Avatar
Yes thats normal.
Old Mar 19, 2007 | 02:48 AM
XB_XIII's Avatar
normal??? im not doubting you.. but i dont think it did that before..is there anyway you could be alil more specific..yours does this?
Old Mar 19, 2007 | 02:49 AM
Max's Avatar
Max
Originally Posted by screamnchikn
Yes thats normal.
I'm just here to second that.
https://www.scionlife.com/forums/viewtopic.php?t=160133
Old Mar 19, 2007 | 03:31 PM
ROBs-xB's Avatar
its normal, its just that your car is not completely warmed up untill
after the blue termom. turns off
Old Mar 19, 2007 | 03:33 PM
badbasic's Avatar
normal!
Old Mar 19, 2007 | 03:36 PM
jsa3mm's Avatar
Read the vehicle's manual and you would know that this is a normal occurrence.
Old Mar 19, 2007 | 03:59 PM
burstaneurysm's Avatar
It's like an echo chamber in here... but yes, it is completely and totally normal. Don't worry about it.
Old Mar 19, 2007 | 04:51 PM
MrRadi8's Avatar
Default Re: Serious question...NEED HELP PLEASE!!!!!!
Yup, what they all said. LOL
I'd happened to read it in my manual before cold weather so I knew it was to happen. A bit aggravating, but that's how it is setup.
Old Mar 19, 2007 | 06:40 PM
Big_Pimpin''s Avatar
What they said. Shortly after I started reading this fine board last fall, this topic was covered. It is a bit strange, but normal for our boxes.
Old Mar 19, 2007 | 08:11 PM
BoogieQ's Avatar
It is normal for almost any car if the temperature is cold enough. Some only do it based on a threshold of how cold it is compared to operating temp. Some simply put a time span in the ECU/PCM such as it will not enable 4th until 60 seconds has passed, etc.
Old Mar 19, 2007 | 08:43 PM
iKevin's Avatar
Mine is even slower going into 3rd right after i crank it. It's a bit of a pain when it's cold but knowing it's there to save the works makes me feel better.
Old Mar 23, 2007 | 08:01 AM
EasysBox's Avatar
it keeps the rpms of the engine higher so the motor will warm up faster...
Old Mar 23, 2007 | 04:23 PM
low_down_xb's Avatar
normal, just give the tranny time to warm up, normal toyota thing, but you could always get a 5 speed and then you will go into any gear you want it to, hahaha
Old Mar 24, 2007 | 05:27 AM
BlackTop's Avatar
I second that
Old Mar 24, 2007 | 05:57 AM
Tomas's Avatar
Admin Emeritus
Normal, covered many times before on ScionLife, it does it to protect the engine (and automatic transmission, if equipped).
This and many other important things are covered in the owners manual you were given with the vehicle.
Read it. Really! You will learn a lot about your new car.
Tom
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
eujin
Feb 23, 2016 01:18 AM
Sgtfluffy16
Sep 30, 2015 01:42 PM
jeremydoc
Sep 16, 2015 11:31 PM
x2x3
Jul 12, 2015 12:44 AM
