mobil 1 0w-40 for s/c?
Old Mar 19, 2007 | 08:05 PM
matt593tc's Avatar
Default mobil 1 0w-40 for s/c?
well its that time of the year again when i'm getting my car ready for the summer and wondering if i can use 0w-40 oil insted of 10w-40 there pretty much the same expect at start up the 0w will be thinner verse the 10w. then under operating temps. they both perform at a 40. what ya think. any recamadactions
Old Mar 19, 2007 | 08:37 PM
jwaggz82's Avatar
I have a 2005 tC and I currently put in 5w40 - I think im going to switch over to a constant 10w40 starting next oil change.
Old Mar 19, 2007 | 08:43 PM
matt593tc's Avatar
i want to go with a 10-40 mobile but i cant find it anywhere just 0w-40 you think it would be alright
Old Mar 19, 2007 | 08:58 PM
jwaggz82's Avatar
But why? Just order it online if you cant find it in the store. Or - call around and find a spot that does have some and get a few cases. Someone has to have it ....its oil.
Old Mar 19, 2007 | 11:33 PM
Spect2K3's Avatar
I personally wouldn't be messing around with the weight of the oil so much, but in any case, you have it in reverse. If you are using those 2 oils, you want to use the 0w oil in the winter for colder starting and a heavier oil, 10w in the summer. It sounds like you have it in reverse. Use the 0W next winter if those are the two oils that you are between.
Old Mar 19, 2007 | 11:47 PM
jwaggz82's Avatar
^ i was about to say that. Also - you dont use a different weight oil just because you cant find the one you need. Thats like saying they ran out of premium gas so I bought diesel or bought regular (but you 100% need premium).
Old Mar 20, 2007 | 06:02 PM
matt593tc's Avatar
i'll just go wid the 10w-40 cause i only drive in the summer anyway
Old Mar 20, 2007 | 10:17 PM
Spect2K3's Avatar
Thats still a pretty heavy weight oil though. Why did you go up from 30 to 40? and why from 5w to 10w?
Old Mar 20, 2007 | 11:51 PM
jwaggz82's Avatar
I honestly dont remember what the book says. Im using whatever is in the book for a 2005 tC. ...is it 30 or 40?
Old Mar 20, 2007 | 11:57 PM
redwar1441's Avatar
heavier weight oil does not flow properly throught the clearnaces in the engine between the bearings. It increases the speed at wich the oil travels and it begins to lose its advantage in reducing friction and reducing engine temps. remember you can skip water across a hot pan if you do it fast enough before anything happens, it takes time for it to evaporate or the pan to cool. Dont mess with what you manual says. Btw the weighs are backwards.
when oil cools it becomes thinner when it gets hot it thickens. remember W is winter 0w 30, 30 in the summer 0 in the winter.
Old Mar 21, 2007 | 11:01 PM
Spect2K3's Avatar
05 should be using 5W-30. 06-07 should be using 5w-20
Old Mar 22, 2007 | 12:02 AM
jwaggz82's Avatar
I stand corrected then - im using 5w-30 and was thinking about switching to 10w-30
richard_rsp
Apr 6, 2017 09:37 PM
05rs1
Dec 9, 2016 02:18 PM
mudguy
Oct 22, 2015 04:31 PM
gyrotech
Scion tC 2G Aero & Exterior
Oct 4, 2015 11:03 PM
BlingSlade
Sep 5, 2015 08:52 AM
