The custom turbo build has begun...
Old Mar 19, 2007 | 08:28 PM
djafropiq's Avatar
Default The custom turbo build has begun...
I have been debating about buying a kit since the second day I've had my car and after intense calculations I have decided I am resourceful enough to piece together my own kit becuase 4400 for a kit +800 ish to install+ 500 worht of gauges = too much for what I want.. And that's kinda on the cheap side.. So I came across this PPC https://www.scionlife.com/forums/vie...158309&start=0 and I jumped on it.. I got a hybrid T3/t4.. Bar and plate intercooler and Piping.. Log manifold.. Blitz BOV.. AEM wideband.. Blitz boost controller.. Pivot turbo timer.. Full apexi n1 exhaust.. Pedals.. Strut bar.. Ngk 1 step colder plugs.. Camcom.. For 1500.. Not to shabby..
Now I got to make a laundry list of what I need to complete it.. I need a new maf pipe because of the 07 differences.. A down pipe cuz it didn't come with one.. Emanage ultimate and pnp harness.. Act clutch or zpi clutch. And some injectors.. But I don't know which size.. I think 550s are too big for my goals..
I plan on running 7psi daily and ill crank it up to 9 or 10psi for fun.. I know its a budget build.. But safety is my first concern.. I already have the meat of the build.. Now I just need some turbo wisdom from all the SLers.. Anything else I need or any advise guys.. All advise is welcomed.. Thanks in advance
Old Mar 19, 2007 | 09:16 PM
318_tC's Avatar
so ur still like 2k away from ur goal
Old Mar 19, 2007 | 09:30 PM
djafropiq's Avatar
Probably.. 800 for the ultimate and pnp.. 350 for injectors.. And I'm not sure how much it would cost a shop to make me downpipe and MAf pipe.. And the clutch.. I don't know if I need one right away.. At 7psi I don't expect to be over 250whp.. Does the slippage get bad over that?
2000 or so sounds right.. Plus install and tune.. But I plan on completing this by the end of summer..
Old Mar 20, 2007 | 01:05 PM
djafropiq's Avatar
Also, is it cool to put on the full exhaust? The reason I ask is because it is 2.5" and I'm not sure if I'm going to be loosing any power since I don't have the turbo on yet.. Thanks in advance
Old Mar 20, 2007 | 02:07 PM
tCduck's Avatar
No you wont youll gain at 2.5, 3 is when you loose power.
Old Apr 2, 2007 | 09:16 PM
djafropiq's Avatar
i was wondering if anyone can put any input as far as getting the pressure sensor for the emanage ultimate, i keep reading that it will be able to tune partial throttle but i dont understand how. also is it hard to add the pressure sensor to the pnp harness or where exactly does it go.. i guess thats more of a question for the dezod guys or garage1217.. thanks in advanced
Old Apr 3, 2007 | 12:29 AM
malloynx's Avatar
www.atpturbo.com
go there for the maf pipe and downpipe... enjoy
Old Apr 3, 2007 | 05:46 PM
djafropiq's Avatar
Originally Posted by malloynx
www.atpturbo.com
nice ill definently hit them up for that.. they have some sweet turbos as well for when i finally upgrade mine..
nobody know anything about the partial throttle tuning with the ultimate?
Old Apr 4, 2007 | 01:49 AM
soros151's Avatar
For Partial Throttle Tuning go with a Dezod Black Box, and use the e-manage for the rest. Unless u use the Greddy Pressure Sensor (I think that's it) to tune the car.
Old Apr 4, 2007 | 04:28 AM
djafropiq's Avatar
Well I'm buying the ultimate so I heard that you can tune partial throttle without the black box.. I just don't know if all I need is the pressure sensor to do so..
YooItsJay
Dec 2, 2015 08:13 AM
xa007xa
Mar 31, 2015 09:24 PM
xa007xa
Feb 22, 2015 03:05 PM
CONCRETETC
Feb 9, 2015 08:05 PM
bambbrose
19
Jan 5, 2004 05:31 PM
