tumal1
08-30-2004, 12:23 AM
Does anyone have a problem with their alignment on their XB? When I am driving on the freeway the steering wheel shakes, but it is OK on the side streets. Do you think it needs to be re-aligned? Thanks Alvin
View Full Version : alignment on your XB tumal1 08-30-2004, 12:23 AM Does anyone have a problem with their alignment on their XB? When I am driving on the freeway the steering wheel shakes, but it is OK on the side streets. Do you think it needs to be re-aligned? Thanks Alvin RPMxB 08-30-2004, 12:39 AM 1) Does anyone have a problem with their alignment on their XB? 2) Do you think it needs to be re-aligned? 1) No... No shake. 2) Yes, take it in; does not sound right. :? RPM HotXB 08-30-2004, 12:44 AM If it only does it a certain speeds it could be your wheels are out of balance. pasteater 08-30-2004, 06:40 PM it is, in fact, that at least one of your tires are out of balance... speaking from a recent personal experience. [/quote] josho66 08-31-2004, 12:51 PM Mine is ok at high speed, I would agree it maybe the wheel balance. I had same problem with other car and that is what it was. neckbonenick 08-31-2004, 01:43 PM unless you've hit some huge potholes or somthing it's probably wheel balance qualityscion 08-31-2004, 02:10 PM Have you put on aftermarket rims? You would experience a vibration between 45-65 miles/hr if they require a centering ring. Other wise it should be a wheel out of balance. tumal1 09-05-2004, 05:05 AM thanks guys for your opinion,im hoping it's just the alignment or balance of the tires. |
