starting from stop
Old Mar 20, 2007 | 04:18 PM
xvbigmickxv's Avatar
Default starting from stop
Is it okay to start in 2nd gear from a stop in this car? it seems much more smoother to me but I dont know if im hurting anything by doing it.
Old Mar 20, 2007 | 04:27 PM
tCizzler's Avatar
It's been discussed MANY times and its fine. 1st almost seem like a granny gear
Although i wouldn't do it uphill too much
Old Mar 20, 2007 | 04:31 PM
Amoxaphobic's Avatar
Yeah, you're ok starting out in 2nd.
Though it does vary from car to car... many (if not most) are ok to start out in 2nd. But I wouldn't recommend doing it all the time (for exmple, uphill as Cizzler said).
Old Mar 20, 2007 | 05:34 PM
tC_rs3_176's Avatar
i wonder how many tc drivers actually start out in 2nd?
Old Mar 20, 2007 | 05:47 PM
MrScion07's Avatar
i do not alot but ill do it now and then
Old Mar 20, 2007 | 06:09 PM
paul34's Avatar
its fine... but I'd rather start in first, because I don't like how you have to be more precise with the clutch and the fact you obviously bog the engine a bit more... but yea, technically its fine, since our engines have enough torque to do a 2nd gear launch.
However, for launches all the time, I say just use first since we're not driving V8s here.
Old Mar 20, 2007 | 06:17 PM
a_german_named_hans's Avatar
i rarely use first. Only when the car is still cold or from a stop light.
Old Mar 20, 2007 | 06:48 PM
tCizzler's Avatar
Same here, but only when i come to a complete dead stop, and then start up again. That is about the only time i use first
Old Mar 20, 2007 | 07:43 PM
FIREDOG's Avatar
for easy driving i do, when its more serious i would not.
Old Mar 20, 2007 | 07:46 PM
tC_rs3_176's Avatar
i'm not trying to sound smart, but when else would you be in first, if not starting from a stop? i mean, i thought this thread was about starting from a stop in 2nd?
(again, not trying to be smart, just trying to clarify)
Old Mar 20, 2007 | 07:55 PM
CuRiOuSfIsH's Avatar
from a full stop, always 1st unless I'm facing down hill.
I have started in 2nd a few times but it takes too long to engage if I dont want to bog down the engine.... yeah, bringing up the RPM's would help but that kills the clutch. There is no serious harm but 1st gear is there for a reason.
Old Mar 20, 2007 | 07:58 PM
timmyinpajamas's Avatar
DeepSouth Scions
y would u want to start in 2nd gear ? .. u have 2 gas it 2 much just 2 take off smooth .. if u know how 2 drive stick then 1st gear should be smooth for you also i only go into second if im still rolling a lil bit
Old Mar 20, 2007 | 08:14 PM
Madilim's Avatar
I start from 2nd gear if I'm still rolling. 1st gear from a complete stop.
Old Mar 20, 2007 | 10:25 PM
Xonic's Avatar
always start in 1st from a complete stop
starting from 2nd puts extra wear and tear on the engine and the clutch
and there no good reason to dump down a 5 speed transmission into a 4 speed.
Old Mar 20, 2007 | 10:27 PM
IcetC's Avatar
i usually start in second when i'm facing downhill just b/c i dont like the jumping that the car will when starting in first but also as xonic said be careful because if i u do it the wrong way you can really hurt your clutch
archael666
Mar 19, 2019 11:52 PM
mw1957
Mar 16, 2015 06:00 PM
idriveanxa
Mar 8, 2015 12:03 PM
CPL_Radar
Mar 5, 2015 05:42 AM
cid_mcdp
Jan 5, 2015 02:45 PM
