Does anyone know the answer to this weird question?
Old Aug 30, 2004 | 04:42 PM
Kristen's Avatar
Default Does anyone know the answer to this weird question?
Ok, I need to know what size screw to use for the back liscense plate? Does anyone know? Any help is greatly appreciated. Thanks! ~Kristen
Old Aug 30, 2004 | 04:48 PM
superjeer's Avatar
Is it a screw or a bolt? I don't have a tC but they all use the same size, as far as I know.. You just need to know if it's a screw or a bolt. I got mine from like autozone or equivalent and they fit fine.
Old Aug 30, 2004 | 07:45 PM
JordanRL's Avatar
Go to an auto-parts store. They will have screws that are specifically designed for license plates. There are 2 different types to choose from:
Metric (Imports)
Standard (Domestics).
Obviously, you have an import. As long as it's a metric screw, it will fit. Any other options of the screw will NOT make a difference of fitment.
Old Aug 30, 2004 | 11:53 PM
erc's Avatar
erc
I had the same problem.. no rear license plate bracket when I bought my car.
I don't think the two holes in the back are for putting screws/bolts directly into. I think you're supposed to put mounting hardware into those holes, and then screw the plate to the mounting hardware..
I just went to walmart and bought the generic license plate mounting hardware. It pretty much consisted of only two plastic bits that snap into the holes, and then screws that go into the plastic bits. It was a crazy tight fit, and I had to use a lot of muscle to get those plasctic pieces into the holes..
Old Aug 31, 2004 | 02:21 PM
Ivben_Blown's Avatar
Default Re: Does anyone know the answer to this weird question?
Just put plate on so I measured screws.....
6mm x 1.00 thd pitch, 16mm long, phillips head screw.
Old Sep 2, 2004 | 05:21 PM
itimebomb's Avatar
stop by a dealership they'll gladly fork up 2 screws.
Old Sep 2, 2004 | 07:38 PM
putz's Avatar
i went to the dealership because i recieved 2 screws less than needed for the mudflaps. i went to my dealer and talked to a random tech and he took me to his tool box and busted out a HUGE thing of nuts and bolts. we went throught them and found a few that would work, FREE =)
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
elzy0000
Jan 16, 2004 04:31 PM
