Any difference between 2007-2006 Scion tC engines?
Old Mar 24, 2007 | 08:03 PM
aryan13's Avatar
Default Any difference between 2007-2006 Scion tC engines?
I'm looking for a CA legal cold air intake for my 2007 Scion tC. I am having a hard time finding one. I was wondering if I could use an intake for a 2006 Scion tC.
Did they make any changes to engine so this would not be possible?
Old Mar 24, 2007 | 08:44 PM
Syldrin's Avatar
yes they moved the mass air sensor in 07
Old Mar 24, 2007 | 08:45 PM
Spect2K3's Avatar
And changed the size as well
Old Mar 24, 2007 | 10:12 PM
aryan13's Avatar
any suggestion on where to get a cold air intake for a 2007 scion tc
Old Mar 24, 2007 | 10:38 PM
Spect2K3's Avatar
trdsparks.com but its not carb legal. I think the aem is carb exempt, but I don't know if they make an 07 or not. I'm not in cali, so i'm not too familiar with all of that fun stuff. On the east coast, its not an issue...
Old Mar 24, 2007 | 10:42 PM
racerxj17's Avatar
07 should be about 10 crank Hp more.
They upped the compression, changed the header, tweaked on the ECU, and some other small stuff. The new SAE rating took away roughly .8 Hp from the entire Toyota line (Tacoma went from 245 - 235, same exact motor)
so with the new rating system and it being 161 now.....its roughly ten Hp give or take.
Old Mar 26, 2007 | 09:28 PM
CRAracer05's Avatar
07 motor also has oil squirters now.
Old Mar 26, 2007 | 10:24 PM
tuffCookie's Avatar
here's A LOT of great info on the differences between the 07 engine and the previous model.
http://www.yoursciontc.com/forums/in...howtopic=16611
Old Mar 26, 2007 | 10:39 PM
CuRiOuSfIsH's Avatar
sorry, there is no CA legal intake.
Old Mar 27, 2007 | 12:36 AM
CRAracer05's Avatar
This is even better yet and should be stickied if not all ready. Shows alot of things people might not have known. 07 intake cam, throttle body,intake manifold could all yeild minor power gains on an 05-06 while 07 pistons may be slightly weaker.Also the alterantor pulley has a clutch now so you might want to consider this if swapping pulleys.
Old Mar 27, 2007 | 04:57 PM
foreverandaminute's Avatar
^^ reading that made me feel like my car's engine is obsolete.
Old Mar 27, 2007 | 08:37 PM
toyota_scion_tc's Avatar
will 07 intake manifold still bolt up to a 06? The actual ports and bolt patten on the are the same aren't they?
Old Mar 27, 2007 | 09:24 PM
nig_nig_the_conqueror's Avatar
Default Re: Any difference between 2007-2006 Scion tC engines?
Originally Posted by aryan13
I'm looking for a CA legal cold air intake for my 2007 Scion tC. I am having a hard time finding one. I was wondering if I could use an intake for a 2006 Scion tC. Did they make any changes to engine so this would not be possible?
Didn't you know? CALIFORNIA _____!
That's why you can't find anything that's legal in California. I suggest you MOVE.
Old Mar 28, 2007 | 11:28 PM
CRAracer05's Avatar
sticky?
Old Apr 26, 2007 | 09:42 PM
NCCOOLJ98's Avatar
does this also apply to the 06 RS2, since it was made later in the year?
Old Apr 26, 2007 | 11:37 PM
VitViper's Avatar
Well now it makes sense why I dyno'd 153whp/153wtq stock.
Old Apr 27, 2007 | 12:55 AM
ESEMRFOZZ13's Avatar
weaksauceparts.com has cai for $237 i believe for the 07
Old Apr 27, 2007 | 03:08 PM
2azfeboost's Avatar
Impossible. Highest we've found for a stock 5spd is 143whp
Old Apr 27, 2007 | 04:39 PM
VitViper's Avatar
Well you can argue with the dyno until you're blue in the face then.
Old Apr 28, 2007 | 03:02 AM
Whocares05050's Avatar
Well you can argue with the Dyno until you're blue in the face then.
That will also depend on the Dyno. Dyno #'s mean nothing, unless you feel it makes you ____ grow another inch, it should be used for tuning purposes,
and to create a baseline HP number, and then immediately (cause of having the SAME atmosphere and such) mod the car to see what it gains.
Its a tuning tool.
