bah..time for a new transmission
Old Mar 25, 2007 | 02:07 AM
wombat's Avatar
Default bah..time for a new transmission
So, I have developed a lower rpm (under 3k rpm) ticking.
It was only under acceleration, so I figured it was a crack in the exhaust manifold or an exhaust leak.
I heard it primarilly in 2nd and 3rd gear, and it got progressively worse.
I dragged it to my favorite mechanic and he went through it with a fine tooth comb, figuring the same thing as me. Well, he found nothing. Decided to look around and drive it some more and we both came to the conclusion its coming from the transmission.
He assumes its probably a gear or something that has broken a cog or whatever off of it and its noticable under said RPM's.
I am going to drag it to a transmission shop he uses and have that guy check it out early next week.
Its a 5 speed, I havent slammed the shifter around, but I am the second owner...so If all else fails and the transmission has to be gone through...
WHAT ARE MY OPTIONS!?
I hate the gearing in the xB. I drive at 70mph alot and 4k rpms dont cut it. Is the echo box the same tranny with different gearing? Is there aftermarket gears for the xB?
Otherwise, I was planning on selling it, but with the money that I might have to put into it, keep it around some more, and figure out what kind of options are available for transmission swaps (that are direct bolt ins).
Anyone know anything I don't?
kevin
Old Mar 25, 2007 | 02:14 AM
Bsbox's Avatar
Bump for good questions i would also like to know the answers to. Keep us updated on the details.
Old Mar 25, 2007 | 03:02 AM
wombat's Avatar
sure deal.
Old Apr 9, 2007 | 07:54 PM
goldenarches69's Avatar
I had the same prob as you and the dealer replaced my clutch under warranty and it went away. The car only had about 16000 miles on it when it was happening. It was something about a loose bearing that was causing the ticking. and it does get progressively worse and more annoying. Good luck.
Old Apr 15, 2007 | 09:30 AM
KaijyuGaijin's Avatar
man drop the celica gts 6 gear tranny and throw some d's on it . lol but seriously go for the 6 speed
Old Apr 17, 2007 | 02:46 AM
joshsbox's Avatar
As far as I know, there really aren't any other transmission options. Anybody have any ideas?
Old Apr 17, 2007 | 03:02 AM
draxcaliber's Avatar
wasn't there a 6 spd tranny with lsd for the xa/xb for sale around here somewhere in the classified section? sounds like it was meant to be
Old Apr 17, 2007 | 03:04 AM
https://www.scionlife.com/forums/viewtopic.php?t=168727
there you go, buy that!
Old Apr 17, 2007 | 05:04 AM
hotbox05's Avatar
the echo tranny drops in. and you should not be at 4k at 70mph.
Old Apr 17, 2007 | 05:16 AM
djct_watt's Avatar
Team Sushi
SEARCH! There are fifty kagillion theads on this.
Old Apr 17, 2007 | 11:25 AM
bfurches's Avatar
Yes you can run the 6spd. Wraith was running the tranny from a JDM levin which he then had kazz install an LSD in. Outof the box though, the levin 6spd will bolt right up to the motor. You do have to have someone modify the subframe a bit (in the since it needs to be cut about 2" in either direction.
...but yes, there is another alternative.
BlingSlade
Oct 19, 2016 12:39 AM
a23r
Feb 1, 2016 04:05 AM
carbinefreak
Oct 21, 2015 02:21 PM
Pkdust
Oct 20, 2015 04:27 PM
user9430961
Sep 24, 2015 01:09 PM
