TRD S/C intake question
Old Mar 27, 2007 | 01:18 PM
DomestickillertC's Avatar
Default TRD S/C intake question
If i end up getting a new intake for my s/c tc, would i have to do a reflash? sorry but im new to the s/c scene.
Old Mar 27, 2007 | 04:27 PM
rvpps2rocks's Avatar
i dont think so but then again im not a supercharger owner...but i dont see any reason or point to have to REFLASH the ecu just because you got an intake for your supercharger. i think you will be okay if u just throw it on there
Old Mar 27, 2007 | 04:31 PM
draxcaliber's Avatar
no, you will not be okay, your tc won't have a clue what is going on and will not be able to use the supercharger. either get the trd reflash, or get it tuned with some kind of piggyback unit.
Old Mar 27, 2007 | 04:45 PM
okay then i stand corrected..hehe
Old Mar 28, 2007 | 06:50 AM
TheQuietThings's Avatar
what?
with just a SC intake?
You will be OK with just an intake with the SC, you will just be running a little leaner than you were without it. The motor should be able to handle it. You won't need a piggyback unit or EMS for something so subtle.
Old Mar 28, 2007 | 03:04 PM
i'm sorry, for somet reason i looked at it like if he got a new s/c would he need the reflash. must not have been paying attention.
Old Mar 29, 2007 | 04:40 PM
KraXxuS's Avatar
The motor should never run lean at all. No matter how subtle it is, the engine might handle it, but eventually it could cause enough wear to damage something. Rod, piston, etc. Wouldn't risk it, at least if you're still under warrenty. Apparently any aftermarket intake installed with the s/c will void the s/c warrenty anyway, whether it says it works with the s/c or not. . .
Old Mar 29, 2007 | 06:02 PM
jwaggz82's Avatar
Ok - here are the facts. With the TRD s/c you 100% want to get the flash. Do not drive the car w/o getting the ecu flashed while the s/c is getting installed.
Second - there is no s/c intake out becides making a custom one or the MMW one. I have a custom intake - look at the picture in my profile. The one i have has a mount comming out of the filter. Do not cut a normal intake and slap it on your s/c setup. you need a custom mount so the filter isnt just handing there.
the air/fuel from what i hear leans out a tad more w/ the new intake but you do not need a piggyback. I will be able to show the dyno results within the next few months ....stay tuned. I will make my own thread when the time comes.
Old Mar 30, 2007 | 01:38 PM
BrEaK_AwaY's Avatar
running slightly lean with an FI car could hurt the engine long term like the one guy said tho...
Old Mar 30, 2007 | 02:39 PM
cessblood's Avatar
dyno results will help out.
Old Mar 30, 2007 | 03:01 PM
jwaggz82's Avatar
I run a methanol setup and rarely keep the engine at high rpms without being in boost. With the TRD map you either want to be at high rpms boosted (so it dumps fuel) or lower rpms at a constant rate.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
mark13018
Feb 6, 2015 08:57 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
JPuehl
Jan 10, 2015 01:01 AM
