REALLY NEED HELP,,,my car won't go over 83mph ?????
Old Mar 28, 2007 | 07:17 AM
tphan80's Avatar
Default REALLY NEED HELP,,,my car won't go over 83mph ?????
here is my story, i just bought 05scion XB for cheap because the car simply won't go over 83mph. i put in CAI, new spark plug Nology silver, change oil but it won't solve the problem... driving under 80mph is perfectly fine, startup fast, drive smooth,.... anyone has any idea that can help me out,,,it drives me crazy.... i slam the gas padel to the the floor and the RPM is close to 5 but it just stay around 83mph...PLEASE HELP... THANKS
Old Mar 28, 2007 | 07:21 AM
raceronabudget's Avatar
are you in that much of a rush where your gonna be driving over 83 all the time?
Old Mar 28, 2007 | 07:26 AM
PakanaHerruus's Avatar
try taking the emergency brake off.. im most cases this helps.. also not that the Xb isnt exactly the quickest car in the first place..
Old Mar 28, 2007 | 08:45 AM
superboxcarxb's Avatar
because it will cause a tear in the space time continuum. Haven't you ever watched "back to the future"? lol. if you went any faster you would be stuck in the past. lol. Isn't that the limit on the xb and the reason the new xb has a digital odometer to discourage people from challenging the odo to max it out?
Old Mar 28, 2007 | 09:09 AM
Tomas's Avatar
Admin Emeritus
Offhand I don't know of any place in the US where it is legal to go even 83MPH on a public roadway, but your xB should be able to do better than that. I have no idea what the actual, verified top end is for my '05 automatic, I haven't tried to push it to find out, but I do know it will see 95 with no problem... That's fast enough for a box.
Tom
Old Mar 28, 2007 | 11:01 AM
ajayaitch's Avatar
Auto or 5-speed?
Will it spin faster than 5k on its way up to 83mph, shifting through the gears?
Old Mar 28, 2007 | 11:48 AM
salteen's Avatar
it's a scion what do you expect!?
83 tops .... that can't be right though, mine's seen 100mph multiple times
Old Mar 28, 2007 | 12:16 PM
Amoxaphobic's Avatar
Yeah, it should go faster than 83... wierd that it stops right there. You said that you bought it for cheap because it won't go faster than that? So you knew that it had a problem when you bought it??
Someone already asked, but does it spin up faster than 5k when shifting through the gears? If not, maybe it's your rev limiter or something that's preventing it from going over that? If it does, maybe it's a computer thing. Sorry, don't know much about the xB engine... but those seem like the two obvious choices.
Old Mar 28, 2007 | 12:38 PM
J1slim's Avatar
this may sound funny, but what floor mats do you have? i use ford escape floor mats for the winter and they are a bit long and go under the gas pedal so i really have to mash on the gas to floor it.
Old Mar 28, 2007 | 12:48 PM
El_Jorge's Avatar
The problem is you dont have a big spoiler on there. Or decals. Once you add a few decals around the car you should have some hp gains. The spoiler will help you make the run from 83mph to at least 155mph.
Old Mar 28, 2007 | 12:54 PM
kevinjr03's Avatar
Is your check engine light on / working properly? Does it come on then go off after you start the car? If it doesn't come on at all it may have been tampered with. You can take it to auto zone to have them see if it is throwing a code. Almost sounds like it is in limp mode.
Old Mar 28, 2007 | 12:56 PM
eburgsspeedyxb's Avatar
yeah, 83 is way too low. The limiter is set at 125, so you still have a while to go.
(and yes, the box is stable at 125 mph, I would know)
Old Mar 28, 2007 | 03:22 PM
stangdude22's Avatar
Yeah, need to know if its an auto or manual. I dont know how u managed 125, but I have gotten my to 105.
Also, you have 5mph more untill you run into an space time continuem issue.
Old Mar 28, 2007 | 03:32 PM
TheRealBen's Avatar
Tom
In the Dallas/Ft. Worth area the high way(I20 I think) is 75(at least through Arlington it is). In west Texas I think they did away with the speed limits.
Old Mar 28, 2007 | 06:13 PM
midgethearsexb's Avatar
DelMarVa
Tom
The dark parts in Texas are 80. Now, back to the topic, you should be able to get your car up to at least 100 without problems. I would check the floor mats like previously mentioned. It sounds stupid, but very well could be the problem. If that's not it I would go to the dealer and then ask a service tech to take a ride with you and show him/her the problem. Although it might not be a big problem that you can't go faster than 83 MPH, your car still is not meeting up to expectations and that can be frustrating. You paid for it, so you have the right to have everything function properly. If it's not topping out where it's supposed to, then it's not functioning properly. This is where warranties come in to play.
Old Mar 28, 2007 | 06:19 PM
El_Jorge's Avatar
How many rockets did you have strapped to it?....lol
I know it takes quite a bit of flooring to hit 105. And thats the MAX Ive hit.
Old Mar 28, 2007 | 06:22 PM
krustytheclown's Avatar
Yeah, There is NO way you can get a xB up to 125. I've also hit 105 on my xB. The speedometer says 125. That does not mean it can get their though. SRT-4's have a 160 MPH speedometer. You cant get there though. C6 Corvettes have a 200 MPH speedometer. They are goverened lower than that, and without the goverener, it probably wouldn't be able to go that fast.
Old Mar 28, 2007 | 06:27 PM
draxcaliber's Avatar
maybe he is driving uphill?
El_Jorge's Avatar
Funny thing is, when I got my custom gauge face done. I had the numbers stop at 100mph. Figured I wouldnt spend enough time over that speed to matter.
Old Mar 28, 2007 | 06:29 PM
salteen's Avatar
both ways hahaha
my s10 speedo used to go up to 85 but it could actually go 90...the cop told me so!
