Tranny issue.
Old Mar 29, 2007 | 01:47 AM
DraconistC's Avatar
Default Tranny issue.
Well i will try to describe this as best as possible. My tC (5spd) whenever I shift up to 3rd gear or down to third gear it makes a grinding noise. It goes into third drives ok, etc just when shifting into it it makes the noise. any ideas? I honestly hope its not a clutch issue and something that is under warrranty but still....
thanks
Old Mar 29, 2007 | 01:50 AM
tCtCtC's Avatar
hold ur clutch longer when u go into gear? sounds like ur letting the clutch go before ur fully in gear
Old Mar 29, 2007 | 01:51 AM
draxcaliber's Avatar
it probably isn't a clutch issue because then i think it would effect all your gears that you shift into.
maybe it is a bad synchronizer, or something is wrong with the shifter itself.
take it in, that sounds like a warranty covered problem.
Old Mar 29, 2007 | 01:53 AM
pollup's Avatar
sounds like a bad driver or a bad synchro. probably a bad synchro.
Old Mar 29, 2007 | 03:23 AM
DraconistC's Avatar
I'll have it looked at on friday when i take it in for the oil and airbag recall. I keep the clutch pedal in long enough as far as that goes. hopefully it is a warranty covered issue. I had my dad and a friend check it out to make sure it wasnt my driving but they had it doo the same thing too.
Old Apr 5, 2007 | 06:49 AM
DANIEL209's Avatar
It is a bad synchro.well that is if your a good driver.i had the same grinding in third gear on another vehicle i owned and it was a synchro.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
Mjdavis1994
Sep 21, 2015 04:42 AM
Gigs
Sep 15, 2015 03:54 AM
TheGovernmenT
Sep 4, 2015 11:57 AM
