Subwoofer to Amp match please help!
Old Mar 29, 2007 | 07:47 AM
Ty_Max's Avatar
Default Subwoofer to Amp match please help!
So I bought a box that holds three ten inch subs...
I already have an amp and sub in one 10" w6
but I like my brain blowing up so I bought two other cheapo subs (50 bucks)
I was wondering
http://www.onlinecarstereo.com/CarAu...roductID=13309
with two of those
can I run it with this.
http://www.onlinecarstereo.com/CarAu...roductID=14873
with out them blowing?
Old Mar 29, 2007 | 07:55 AM
chrischoi's Avatar
I'd guess yes.
Old Mar 29, 2007 | 04:13 PM
rvpps2rocks's Avatar
i wouldnt mix and match subs..because every sub will produce different sounds at certain frequencies..it just wouldnt sound good. if u want to blow your brains out why dont u just spend the money on 2 12's or 2 15's or even an 18"
Old Mar 29, 2007 | 04:17 PM
Ty_Max's Avatar
I like the different sounds haha
Gives you a surreal feeling
and why not 15's or 18's
Cause I own a tc not a bronco!
Old Mar 29, 2007 | 06:30 PM
nodsetse's Avatar
This is true, and I also strongly recommend against what you're considering. At some frequencies there will be large cancellations, with large peak combinations at other frequencies. Your bass won't be accurate, flat or smooth, but very uneven and not at all natural sounding. For example, you could wind up with something flat at 30Hz, -9dB @ 40, + 12 @ 50, -6 @ 60 and +9 @ 80Hz, which would suck bad.
I'd suggest either sticking with your current JL, and if you want more output, add another of the same. You could also drop the JL and just use the cheap subs instead, as that should sound much better than using all 3 of them all together.
Go ahead and experiment if you'd like, it's a great way to learn about this kind of thing if you have the time, money and don't mind investing the effort required. I'm confident you'll eventually figure out it's a bad idea.
Old Mar 29, 2007 | 11:21 PM
Ty_Max's Avatar
I was thinking of matching the frequencies with the bass controller
prescottn
Scion tC 2G ICE & Interior
Apr 26, 2016 01:14 AM
prescottn
Feb 24, 2016 11:57 PM
prescottn
Oct 8, 2015 05:31 PM
DannyBoy65
Sep 21, 2015 06:23 PM
SJMiller
Sep 12, 2015 06:33 PM
