Kloz
09-01-2004, 11:02 PM
Does anyone know if rims that are 18x7.5 with a +45mm offset will fit? I know that the size is right its the offset that worries me. Any info will def help!!
View Full Version : Rims Question Kloz 09-01-2004, 11:02 PM Does anyone know if rims that are 18x7.5 with a +45mm offset will fit? I know that the size is right its the offset that worries me. Any info will def help!! 1002 09-03-2004, 04:55 AM I dont knoe much about rims, but I would suggest getting specs from toyota! But 4 lug is 4 lug... Can you at least try them out...take one tire and find out. Im kind of curious to know as well... phillythunder 09-03-2004, 04:57 AM i have 19x7.5 with a 2" drop on my box and it fits fine :lol: TheScionicMan 09-03-2004, 06:04 AM First of all, there are two different sizes of 4-lug wheels. The Box takes 4x100. Height and width should be OK, but the offset may be close. Many people running +42 or higher have run spacers. It may depend on the rim design too, but there is an issue of contact with the rear trailing arm (? don't quote me on that) I think that was where the trouble came up. Check out http://www.onetongarage for a really nice spacer, actually better than a spacer specifically designed for the scions. Wheel fitment thread: http://www.scionlife.com/forums/viewtopic.php?t=348 BTW, I'm moving this thread to Tread and Butter since it's not a regional thing... DenZinz 09-03-2004, 06:07 AM Does anyone know if rims that are 18x7.5 with a +45mm offset will fit? I know that the size is right its the offset that worries me. Any info will def help!! You will need a spacer in the rear to clear the control arm. |
