Can you post pics of your...
Old Apr 3, 2007 | 03:08 AM
Scott8's Avatar
Default Can you post pics of your...
I need some pictures on where people connected there AEM wideband sensor on the exhaust?
I need to have a bung welded onto the exhaust, and I just wanted to see how everyone else is mounting theirs.
Thanks-Scott
Old Apr 3, 2007 | 03:44 AM
yamaha16bw's Avatar
I dont have a pic but mine is welded in pointing straight up right next to the oil pan on the s-pipe.
Old Apr 3, 2007 | 03:58 AM
Scott8's Avatar
SO the s-pipe is the best place for it?
Old Apr 3, 2007 | 04:09 AM
mike6789k's Avatar
s-pipe seems a bit far i think... it should be closer to the engine
Old Apr 3, 2007 | 04:14 AM
Scott8's Avatar
I will have to look at the manual, but I think it says 18 inches to 36 inches if you are running higher horsepower and the motor is warmer. I was thinking of the bottom of the down pipe, after the stock o2 sensor.
Old Apr 3, 2007 | 04:23 AM
mike6789k's Avatar
that would make more sense
Old Apr 3, 2007 | 04:26 AM
Scott8's Avatar
that's why I want to see what everyone is doing
Old Apr 3, 2007 | 01:01 PM
318_tC's Avatar
mines about 8 inches down off the downpipe....
Old Apr 3, 2007 | 02:50 PM
krdshrk's Avatar
Mine's actually on my midpipe... I think.
Old Apr 3, 2007 | 04:29 PM
Scott8's Avatar
I thought it needed to be before the Cat? Wouldn't the mid pipe be too far down the exhaust stream?
Old Apr 3, 2007 | 05:24 PM
yamaha16bw's Avatar
Thats about where mine is.
Old Apr 3, 2007 | 06:07 PM
krdshrk's Avatar
I don't have any cats. :D
Old Apr 3, 2007 | 07:28 PM
satoman44's Avatar
my friend and i both have aem units. mine is mounted at the bottom end of my downpipe after my cat (yes, my downpipe is catted). my friend has his on his s-pipe. at idle, i read normal afrs fluctuating around 14.8, while his registers a lean condition (gives no reading, "---"). only when he starts to drive the unit gives a normal reading. i think this might be due to the fact that when its on the s-pipe, it doesn't see enough exhaust gas volume to give the unit a reading.
Old Apr 3, 2007 | 07:37 PM
jrodTc's Avatar
I've got mine on my s-pipe and I read my AFR's fine at idle, WOT and PT. Its at the very beginning of my s-pipe right after where the downpipe meets up with it. We calculated it to be about 30 inches or so from the exhaust manifold. Instructions say anywhere from 12-36 inches away.
Old Apr 3, 2007 | 11:22 PM
Scott8's Avatar
I think if I put it on the bottom of the downpipe I should be fine with it being far enough away
Old Apr 4, 2007 | 12:09 AM
rodlandscion's Avatar
Your friend has an exhaust leak at the downpipe to s-pipe conncection. I have mine next to the stock secondary sensor in the s-pipe, and I read a fine 14.8 at idle and a good afr at wot. However, my s-pipe downpipe connection came loose and my wideband was doing what your friend's is Sato...
Old Apr 4, 2007 | 04:05 AM
satoman44's Avatar
thanks! i'll be sure to let him know next time i talk to him.
Andreas24
38
Sep 22, 2015 06:23 PM
JinH
Dec 27, 2014 01:27 AM
daversion
Oct 20, 2003 04:43 PM
