Regional - Pacific Mid CA, NV
Need Help Lambo tC electrical issue.!!!
Old Apr 3, 2007 | 09:03 PM
XBbarkeeper's Avatar
Default Need Help Lambo tC electrical issue.!!!
We got a tC with lambo doors in service today that has an electric issue surrounding the lambo doors. It is draining the battery!
Has anyone else had problems with this? What was the problem?
Alignment seems to be fine! I am having them check for a grounding issue! Can you guys give me some input!
Old Apr 3, 2007 | 09:57 PM
jambaxb's Avatar
If the wiring was spliced and extended, I would check all of the splices.
You may have to remove the doors and check everything they topuched to do the vertical doors.
Old Apr 3, 2007 | 11:00 PM
ScionSniper's Avatar
Yah, I would look for a ground somewhere in the wiring for the door.
Old Apr 4, 2007 | 06:33 AM
SquallLHeart's Avatar
electrical issue while dealing with a mechanical thing....
hmm.. yeah... interesting... sounds like a ground... whose car, and who installed it?
technically, the wiring has enough length to be pulled thru without needing to splice or extend any wires.
i'd check in the immediate vicinity of the hinge area as to what could've happened during the install.
Old Apr 4, 2007 | 04:32 PM
etli's Avatar
Maybe they didn't put enough slack in the wiring when they threaded it through the hinge and it pulled out of it's alignment somewhere?
Just guessing....
Old Apr 5, 2007 | 03:41 AM
Scikotic-tC-'s Avatar
Just unclip the wiring harness pull back the sleeve and check the wires............
Old Apr 5, 2007 | 11:01 PM
Thanks for the help it was a bad splice! Thanks Again!!
The tC is for sale @ Scion 101 All is fixed!
Old Apr 6, 2007 | 06:53 PM
etli's Avatar
Hey Robert, what days and hours are you at Scion 101? I'll stop by on occassion to hang out and check out the revamped dealership.
Old Apr 7, 2007 | 05:47 PM
10-7 Everyday except wed-thurs.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
prescottn
Feb 24, 2016 11:57 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
Gigs
Sep 15, 2015 03:54 AM
Wrencher
Jul 29, 2015 01:38 PM
