Blitz Sc some problem
Old Apr 4, 2007 | 04:19 AM
ala_HELG's Avatar
Default Blitz Sc some problem
All greetings. I have bought BLITZ Sc, but I can not understand with ECU. The instruction on installation on Japanese, whether has who the instruction in English? And still a question. What wire with charger goes on ECU? What signal is necessary with CPU? In the instruction the compressor is established on toyota bB, but at me toyota FunCargo, that in other the same most, but a computer for some reason another...
Old Apr 4, 2007 | 06:40 AM
mbaledge's Avatar
tC squad
DUDE!!! WHERE DID YOU GET THAT?!?!?!
I've never seen that before in my life. I want one. Bad.
Old Apr 4, 2007 | 06:45 AM
xezerax's Avatar
umm wrong section.
Old Apr 4, 2007 | 07:25 AM
Yankee21's Avatar
That's not for the tc. It needs to get moved...
Old Apr 4, 2007 | 08:11 AM
ala_HELG's Avatar
Actually vichles xB, bB, funcargo have Identical a running part and the engine.
And ECU differ.... Here also it is interesting what signal undertakes with ECU and what role it play the compressor?
Old Apr 4, 2007 | 05:49 PM
mbaledge's Avatar
tC squad
Tee-hee! Silly me, i thought if was for the tc...
Old Apr 6, 2007 | 01:57 AM
proctorsilex's Avatar
dude, what is your native language?
my blitz sc should be coming soon. i don't know whether our ECUs are the same, but maybe i can help when i get mine.
Old Apr 6, 2007 | 06:52 AM
ala_HELG's Avatar
I hope for your help. My compressor too should arrive on April, 20th. And your machine at us refers to toyota ist.
my native language Russian, but English I slightly know
Old Apr 6, 2007 | 03:44 PM
i had a russian girlfriend once, so i tried to learn russian, but i don't know how to transliterate into english letters or how to write in russian :/
the blitz comes with a piggy back controller that works on top of the stock ECU.
it is supposedly NOT very good at all. i will use what comes with the blitz at first, but i plan on switching over to a MegaSquirt for engine control.
i am uncertain what else to say right now.
dosvidania!
Old Apr 6, 2007 | 05:33 PM
carcandymotorsports's Avatar
let me know if you need help I am fluent in Russian. I was born there. I am running the same supercharger on my xB and have wiring diagram in English. I can fax it to you if you need it. I will be switching to emange to properly tune the car. You can contact me at gregb@carcandymotorsports.com
Old Apr 9, 2007 | 02:14 AM
ala_HELG's Avatar
dosvidania!
zdravstvuite
And you when will put the compressor? Lay out please the detailed instruction. Than are bad standard ECU? What does MegaSquirt?
Old Apr 9, 2007 | 02:55 AM
megasquirt is a electronic fuel injection controller that can also control ignition and vvt-i. it is cheap, but takes much more effort to install.
http://www.bgsoflex.com/megasquirt.html
i should have the blitz this week.
Old Apr 9, 2007 | 07:55 AM
ala_HELG's Avatar
It is tempting.... How many costs? How to change the charge of gasoline? Whether it is necessary it as that to program or adjust?
Old Apr 10, 2007 | 01:08 AM
around $400 US if you assemble it yourself, which includes soldering., $500 or so already built.
there is windows and linux/unix software available to program it. i use megatunix for linux.
i will install my blitz by wednesday!
Old Apr 10, 2007 | 02:22 AM
ala_HELG's Avatar
Dearly, in Russia the average salary 400 $.... At me the truth 1000, but all is equally dear...... But to solder I be able well. The equipment at me is
Old Apr 28, 2007 | 11:42 PM
i finished installing the blitz today.
https://www.scionlife.com/forums/vie....php?p=2527510
there are about 11 wires that connect to the ECU: ground, ignition, fuel injectors, et cetera.
you might want to get the electrical manual for your car to make things clear for you.
the english instructions for the blitz are not good.
it does make significantly more power, but it will not push you back in your seat.
good luck
Scionxa180
May 6, 2015 05:38 AM
Scionxa180
Apr 28, 2015 03:07 PM
NCCOOLJ98
Apr 20, 2015 06:08 PM
thefoth
Jan 10, 2004 07:41 PM
proto_k7
Dec 24, 2003 07:50 AM
