2000 watts RMS system's battery, alternator, big 3 suggest?
Old Apr 4, 2007 | 09:02 PM
Italiangurl's Avatar
Default 2000 watts RMS system's battery, alternator, big 3 suggest?
I got three questions related to this and need some help on it.
1. Im going for big three upgrade and i checked over eDmental design and they sell it for 100 buck and i do think its cheap but do you find or know anywhere that are cheaper?
2. the battery issue, since my system handle 2000 RMS watts, does one battery is good enough? need another one? if so, which battery is the best for that?
3. Since my system is 2000 RMS, its obviously i need a better alternator so how to upgrade it to make it high output and where to buy one??
the box is on the way so i want to make sure im doing the right thing before creating a mistake and cause other to fall through.
https://www.scionlife.com/forums/vie...153&highlight=
Old Apr 4, 2007 | 09:14 PM
nodsetse's Avatar
1. Don't know of any other brands that make a kit specifically for doing a 'big 3'. You could buy whatever brand parts you want and make your own if you want.
2. The only reason to add another battery is to extend your engine-off listening time. If you want to listen for long periods w/o the car running, then add another battery. If you do, make sure to get a solenoid or isolator, of the type that will only parallel the batteries when the engine is running (so when the key is off, your audio system will only run from it's own battery, not the car's battery).
3. I wouldn't be so sure a hi-po alternator is required, just because your amps are rated to produce 2k watts. They won't actually be doing so unless you're constantly cranking it to the max spl and leaving it there. Why not wait and see how the stock alt does? You can always upgrade it later if the stock unit fails.
Old Apr 4, 2007 | 09:26 PM
i will see how my ALT can handle the power and will let u guys know. the average of listening time to my music is prob 3 to 5 hours.
Old Apr 4, 2007 | 11:17 PM
nodsetse's Avatar
Well if you intend to listen to the system for 3-5 hours with the car off, then yes, please add another battery for the audio system so you don't kill your starter battery. It's important that a solenoid is set up the way I described, because if both batteries are always connected, you'll just drain them both. Implemented correctly, you won't have anything to worry about.
Old Apr 5, 2007 | 04:30 AM
Neothin's Avatar
adding batteries never hurts. It allows for voltage to be more stable (figure with more batterys, more stored power is available, so when the system hits, more power can be sent to it). PM rocketgyrl about battery choice
the big 3 is nothing more than 3 wires. positive to alternator, chassis to ground, and engine block to chassis. i used 0awg wire. eD's site is incorrect. talk to chris and he'll get you the correct price.
iraggi alternators... mmmmmmmmmmmmmm
Old Apr 5, 2007 | 05:02 AM
what u mean incorrect price? what it suppos to be?
Old Apr 5, 2007 | 05:14 AM
Neothin's Avatar
less. i ordered the 0awg kit a while back when i did my system and chris corrected teh price on my list. i guess the webmaster still hasnt gotten around to changing it.
Old Apr 5, 2007 | 05:17 AM
What the price that it suppose to be?
Old Apr 5, 2007 | 05:18 AM
Neothin's Avatar
can't remember
EvalEvan66
Jan 27, 2015 02:26 AM
EvalEvan66
Jan 16, 2015 08:34 PM
cwong1001
Dec 3, 2014 03:30 AM
scioninla
14
Oct 18, 2003 03:46 AM
vpkb
12
Oct 8, 2003 04:17 AM
