Turn of airbag waring light?
Old Apr 5, 2007 | 03:54 AM
LostCause's Avatar
Default Turn of airbag waring light?
HI guys,
Cars been in a minor accindent but the airbag light went off...Ive searched but haventh found a clear answer to turn it off.
Could someone please help.....extremely anoying too look at
Any help would be apreciated
Old Apr 5, 2007 | 04:06 AM
engifineer's Avatar
Well, I would take it in and have the airbag system checked. That is what the light is for.
Old Apr 5, 2007 | 04:09 AM
LostCause's Avatar
Default Airbag
Well were im from the toyata dealers dont sell or service scions.
I had mine imported...the cars been fix in a body shop but the light is still one...is there a easy way to turn it of?
Old Apr 5, 2007 | 04:50 AM
engifineer's Avatar
fixing the airbag system.
If you took it to a body shop I would take it back and ask them to finish the job. You could try resetting the ecu, but if that doesnt do it you need to get it fixed. The airbags will not deploy if you get into an accident right now.
Old Apr 5, 2007 | 06:08 AM
tCjosh's Avatar
^^^yep what he said...
Old Apr 5, 2007 | 07:18 AM
tweetertc's Avatar
if the light is on... usually is means either a sensor is still damaged,,, or there is too high or lowof a resistance in the sensor wires.,... depending on how you were hit is could be either or both.. a scan tool can properly diagnose the problem but the problem is finding a service center.. it might end up being worth the drive to get it fixed.. most body shops can try to repair it.. but a certiffed toyota mechanic is always the best way to go..
Old Apr 5, 2007 | 10:59 AM
Otocan's Avatar
any Toyota dealership will service a Scion, that is, unless for some reason the techs and service department have a specific grudge against Scions on a personal level.
Did you miss the fact there's a Camry 2AZ-FE engine under the hood? Celica brake system? Toyota Avensis chassis?
yeah....
and engifineer had it right, cross your fingers you don't get in a serious accident because your airbag will NOT deploy.
it's most likely a damaged or disconnected sensor in the front of the car from either the accident or the repair.
Old Apr 6, 2007 | 01:38 AM
LostCause's Avatar
Default Airbag
Well tnx for the feedback..
Ill see what i can have done
setpol
Feb 17, 2015 11:33 PM
fur_pig
Scion tC 1G ICE & Interior
Jan 27, 2015 12:52 PM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
