I burned nine albums onto a cd in MP3 format- I used a program that came with my son's Dell. Anyway, on the computer the albums were recorded to one directory, but are recorded with all of the songs to each album next to one another. However, when I play the MP3 CD on the stock Pioneer radio the songs seem to not be in the order they were recorded. The songs are numbered 1-94 but they are all mixed up. Any ideas????
DrG
ImBack
09-03-2004, 03:18 AM
mistakenly hit the random button or is it selected on the head unit?
Max2k
09-03-2004, 03:39 AM
They're probably burned in alphabetical order, which is a problem when each file name starts with what number track it is (i.e. 01 Holidays In the Sun.mp3, 01 Nevermind.mp3). What you want to do is open Easy CD Creator (your kid's computer probably already has it installed, look in the start/programs/roxio menu), go to file/new/mp3 player disc. From there you want to drag folders with your music onto the disc, one folder per album. Burn that fool, pop it in the CD player and viola!
fireballfish
09-03-2004, 04:41 AM
does the random function play files from all folders, or just the current one?
TheScionicMan
09-03-2004, 05:41 AM
If you hit random once, it skips thru the current directory. If you push and hold it, you'll see another symbol above it and it will skip thru all the folders.
DrG said they were all in the same folder. Actually either solution could be correct, but I'm guessing it's the alphabetic issue. I do mine in the folders.
Also, watch out for the 01,10 issue. If your MP3 ripper doesn't add a leading zero to the single digit numbers, the computer will align them weird:
11
12...etc.
I was not in random playing order. I suspect the alphabetical issue may be the problem. I will try to reburn the music into separate folders and see what happens.
DrG
Back_In_Black_xA
09-06-2004, 01:11 AM
When I burn my mp3 CDs I put each band's songs into it's own folder and I number each song 1, 2, 3, 4, etc... how I want them in order so they will play the way they are on the CDs...
You learn something new every day. I never burned MP3's before. So, it was my error that they were mixed up. They were recorded in some alphabetical /number order. I reburned the albums into separate folders and they are now in the order I wanted them to be. Too bad the cd player can't give readout of album name and song name at same time.
DrG
