HELP Car wont stay on - Problem solved
Old Apr 6, 2007 | 08:13 PM
GEO's Avatar
GEO
Default HELP Car wont stay on - Problem solved
I need help big time. Basically the car turns on and as long as I dont stop pressing the gas it will strugle to stay on. I had removed the charge pipe with filter as I was trying to readjust the pipe. ZPI stage one. I also did remove the map sensor but plugged it in with out damaging it. All connections are plugged. I was able to drive it first and second but it shuts down as soom as I let go of the gas. I have no idea what is wrong. All advice is appreciated since I'm suppose to be somwhere in a couple of hours.
Old Apr 6, 2007 | 08:14 PM
318_tC's Avatar
Check ur charge piping.
Old Apr 6, 2007 | 08:15 PM
GEO's Avatar
GEO
Check for whst exactly? It's connected good to the turbo and the map sensor seems to be ok.
Old Apr 6, 2007 | 08:49 PM
jrodTc's Avatar
Check all the couplers around your intercooler piping going in and out of it. If those come loose there's ur problem. I had a similar issue, scared me ____eless but that's all it was. Your MAF is reading air coming in, but that air isn't making it to the throttle body it sounds like unless you floor it. I ono for sure though.
Old Apr 6, 2007 | 08:53 PM
sddykstr's Avatar
Yeah check all of your couplings. Just out of curiosity, what does your vac gauge read?
Old Apr 6, 2007 | 09:16 PM
GEO's Avatar
GEO
Thanks for the advice I was able to fix the problem. It seems that the MAf did not like the air filter being very close to it. I put the airfilter further away and re tightend all of the couplers and bingo it worked. Thanks again all for the quick responses,
Old Apr 6, 2007 | 09:28 PM
bcnu_702's Avatar
Glad you got it working. I will make sure I remember this just in case it happens to me.
Jordly221
Feb 13, 2019 05:29 PM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
Tylersheehy
Scion tC 2G Aero & Exterior
Jan 4, 2015 09:19 PM
fluxingnation
Dec 26, 2014 04:28 PM
bruceb25
Nov 23, 2014 04:52 AM
