problems with fuses
Old Apr 8, 2007 | 03:14 AM
fat-boy's Avatar
Strictly Scionized
Default problems with fuses
my dome light,head unit, the lights for high beams and the temp lights will not come on my lighter works find I checked all the fuses they are all ok . what's going on ?
Old Apr 8, 2007 | 07:26 AM
OldYeller's Avatar
I had problems with a fuse and could not find it. The directions in the owners manual leave a little to be desired. The fuses are in two different places. I got mine fixed under warranty. Good luck.........
Old Apr 8, 2007 | 04:07 PM
fat-boy's Avatar
Strictly Scionized
dose anyone have a fuse diagram for the fuses in the dash
Old Apr 8, 2007 | 04:36 PM
mom2boysdadsxb's Avatar
How's the 15 amp DOME fuse that's in the driver side of engine compartment relay box look?
Old Apr 8, 2007 | 05:27 PM
OldYeller's Avatar
The Dome fuse is listed as a 15 amp fuse that controls the clock, interior light, and "gauges of meters"----I assume the last notation would be the temp gauge. The fuse is listed as #4 which is in the engine compartment and is the top most fuse in a line of five fuses. In the instrument panel, fuse #14 is listed as the ACC, Gauge, Wiper and ECU-IG fuses. It is the very top left fuse. Fuses 9 and 10 are for the headlights and they are in the engine compartment and are the top two in the section of three fuses at the bottom of the panel. The headlight fuses control low and high beam. From the problems you list it is either more than one fuse or some other problem as no one fuse controls what you have out. Good Luck!! My fuse diagram is in the very last few pages of the owners manual just before the index...........
Old Apr 9, 2007 | 03:03 AM
fat-boy's Avatar
Strictly Scionized
it was the one under the hood I did not know there was one for dome light there. my car was broken into and they stole my manual. now I just have to find out what's wrong with my head unit it will not turn on
Old Apr 9, 2007 | 12:26 PM
integroid's Avatar
Get a multimeter and check every fuse. The fuses for the radio are tied in with other fuses so check all of them if you dont have a manual or take it to the dealer and ask them. They should know which fuses are tired in with the the radio.
idriveanxa
Mar 8, 2015 12:03 PM
EvalEvan66
Jan 27, 2015 02:26 AM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
EvalEvan66
Jan 16, 2015 08:34 PM
