couple quick zpi questions
Old Apr 9, 2007 | 11:22 PM
jaxtcracer's Avatar
Default couple quick zpi questions
okay i'll keep this short. basically, i plan to order a stage 0 kit over the summer but i have a couple questions regarding options.
1. HKS SSQV- i need to get the optional flange with that, right? also, what size flanges do we use? 50mm, 60mm, or 65mm? what's the difference?
2. zpi pre-tapped oil pan- i can get it with oil line size of -8, -10, or -12. which should i get? what are the oil line sizes in our tCs?
3. emanage blue- is there a harness available? ZPI's selection of harnesses seems to be for the emanage ultimate. that isn't compatible with the blue is it? if there's no harness, i just splice the wires in, right? side note: if i get the pressure sensor upgrade, will i need a retune or will it just run better off of the base map i'd already be using?
alright, thanks for the answers. i've learned a LOT by searching around the forums but i still had these questions.
Old Apr 9, 2007 | 11:31 PM
draxcaliber's Avatar
the stage 0 kit comes with all the stuff to tap your own pan, you don't need to order a pre-tapped one.
redwar1441's Avatar
if you buy everything together they will set you straight. The bov needs the flange welded on and they will do it for yu. The pan will need to come with w/e size they provide in the turbo kit. as for the emanage harness why dnt you just call them? and dont forget an a/f guage that needs to be welded int the downpipe, which they will do it you rder it all from them at once.
Old Apr 10, 2007 | 12:10 AM
bcnu_702's Avatar
Whats up drax! How hard is it to tap an oil pan. I mean if ZPI gives you the tools necessary, it doesn't sound that difficult. Thanks!
-Chris
Old Apr 10, 2007 | 12:15 AM
from what i've read, it isn't that hard, if you can install a turbo, you can tap a pan. so it shouldn't be too hard for you or your installer.
Old Apr 10, 2007 | 01:08 AM
olaHalo's Avatar
gl with the kit
Old Apr 10, 2007 | 10:06 PM
redwar1441's Avatar
um....you need a welder.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
ShadowMage
16
Jul 25, 2004 06:02 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
