Exhaust Gasket
Old Apr 12, 2007 | 02:56 AM
Giovanni's Avatar
Default Exhaust Gasket
I did a search but nothing turned up. I have the Borla axle back and I am having some problems with rattling. I determined the problem was the gasket that fits between the oem pipe and borla pipe. When I removed the clamp the gasket was nothing but a coil of metal. So I ordered a new one and installed it....rattle cured. Well, that was a month ago and the rattle is back. I removed the clamp and once again the gasket is a burned up coil of metal again.
So, am I missing something? Is a different gasket used when the borla exhaust is installed?
Old Apr 13, 2007 | 03:55 AM
Giovanni's Avatar
anybody???
Old Apr 13, 2007 | 05:53 PM
andrewdustin's Avatar
i don't have an answer, but i have the same problem.
Old Apr 13, 2007 | 09:06 PM
Giovanni's Avatar
thanks for the reply man and although it sucks, i am glad I am not the only one experiancing this. I thought it was something i was doing wrong.
Old Apr 13, 2007 | 09:10 PM
cadon69's Avatar
I don't know why this is happening. I do know that with my greddy evo2, came a new gasket that wasn't all metal. It had metal around the outer edge of it to hold it together but the inside of the coil seemed to be cardboard or something of the sort. You might want to try getting a hold of Greddy and see if they will sell or give you a gasket. I have had mine on for at least 2 or 3 months and not a single problem with it (knock on wood). Hope that helps.
Old Apr 13, 2007 | 09:13 PM
Ghost_1's Avatar
It's been a while since I installed my strup exhaust. From what I do remember I think the gasket was a kinda paper ring with metal around it. Once the pipes are put together the gasket would fill in the surround in the pipe.
I also remember that the clamp has to be on at a 45-55 degree angle or the clamp wouldn't sit right. Being aftermarket my strup exhaust took a little work. Anyway, I know I had a wierd rattle for a while, so I started to position the clamp in different angles. Funny thing is the best angle made the clamp look like it wasn't on right.
Try to loosen the clamp and reposition it. Adjust the exhaust muffler pipe to sit on the OEM pipe and then refit everything back together. see what happens. I know it took me about three tries before the pipe set right and the rattle went away. Haven't had to mess with anything for over a year now.
Old Apr 13, 2007 | 11:55 PM
Giovanni's Avatar
Thanks for the info fellas. The gasket for the Borla is the same as you guys described. It is a metal ring with some type of green gasket paper in the middle. However, when it burns off, all that is left is the metal ring.....no paper.
I guess there is a chance I didn't line it up perfectly when I replaced it so I will try that and see. I'll let you know what happens
Thanks
carid
Scion FR-S Drivetrain & Power
Jul 15, 2015 11:26 AM
P944
Apr 30, 2015 06:04 PM
PTUNING
Dec 11, 2014 08:09 PM
PTUNING
Dec 6, 2014 03:58 PM
