Upgrade trunk light : automatic on/off with LED
Old Apr 14, 2007 | 05:51 AM
Leganza's Avatar
Default Upgrade trunk light : automatic on/off with LED
PLEASE DISREGARD AUTO ON/OFF WIRING PART!!!
OK. now I realized it is already designed as turning on and off automatically. I did such a useless work in the below. So just disregard wire and switch parts in this thread, and just enjoy with LED parts....
(ORIGINAL THREAD)
Hey guys!
Have you ever experienced some difficulities for finding light switch in trunk at night? I just upgraded my trunk light to get turned on/off automatically when the trunk get opened/closed. I also changed the bulb into eight LEDs (5630 size, 3 chip SMD type) and this LED contains three chips (normally there's only one chip on SMD type LED), so it is way brighter than normal one chip LED.
Anyway I'll show you what I did.
1. Take off trunk light and cut off all the unnecessary parts as below pictures.
Be careful with + / -
2. Solder LEDs onto PCB (specially designed for SMD/superflux LEDs application) and also solder lead wires onto PCB
* Front
*Back
3. Hook up lead wires from PCB and trunk light
4. This is the switch that operates backward compared to normal switch. It's off when switch pushed and it's on when switch released.
5. Make a hole that fits in the switch onto plastic molding at trunk and install switch and then connect lead wires.
6. poke lead wires from switch into trunk trim, and then get lead wires out of the hole of trunk light. Then cut one of the wires(+ or -) of original haness (I actually cut orange color wire) and then connect two lead wires to each wires' ends that you just cut. Perfectly insulate them and put them back into trunk trim, and also put trunk light back on and that's about it.
7. Now everything's done.
(Daytime shot)
(at night)
How's that guys.. I love it. Now I don't have to find the switch at night. ^^
Old Apr 14, 2007 | 05:58 AM
riboflavin's Avatar
Mine turns on when I open the hatch?
Old Apr 14, 2007 | 06:00 AM
Leganza's Avatar
Is it right????? but then how come the light has a switch??
toby3002's Avatar
yeah the trunk light is already auto-off when you close the trunk...nice work though on the led light!
Old Apr 14, 2007 | 06:02 AM
O5_TRD_tC's Avatar
yeah dude the light auto turns on when u open the hatch...
Old Apr 14, 2007 | 06:04 AM
riboflavin's Avatar
If you switch it on, it turns on and off automatically and if you turn it off, it never turns on.
Old Apr 14, 2007 | 06:11 AM
all4degame's Avatar
nice work with the LEDs, but as the others have said, the trunk acts just like a dome light.
Old Apr 14, 2007 | 06:12 AM
Dakine's Avatar
Concept in Motion Crew
so, u didnt know it auto. turns on and off?
Old Apr 14, 2007 | 06:33 AM
mandangalo's Avatar
Werd, it's like the ceiling lights, but it only has a "off" and "door" position, so to speak
Old Apr 14, 2007 | 06:57 AM
Leganza's Avatar
I really didn't know that... man, I made hole and installed switch on trunk trim!!!
I should've not done it!!!!
Old Apr 14, 2007 | 03:10 PM
paul34's Avatar
hahah. It's ok dude, at first I thought that too, but that's because mine initially came with the switch in the OFF position. If you just turn it on, it auto turns on/off when opening/closing the hatch.
Old Apr 14, 2007 | 03:53 PM
Zebman's Avatar
That trim SHOULD cost no more than $20 (knowing dealerships, i'm sure you'll be bent over) so you can just replace it if it bugs you.
Old Apr 14, 2007 | 04:39 PM
Leganza's Avatar
OK.. Thanks, That's kind of inexpensive less than I thought.
Old Apr 14, 2007 | 05:40 PM
Zebman's Avatar
Well i'm just estimating. It would be mad to cost any more though for what it is.
Old Apr 14, 2007 | 06:02 PM
SquallLHeart's Avatar
perhaps you should edit some parts of the thread or so as not to confuse others into making the same mistake.
Old Apr 14, 2007 | 06:22 PM
ARIZONA-TC's Avatar
dang dude that sucks well if it makes you fell any better i didnt no that it auto turns on and off...
Old Apr 14, 2007 | 06:27 PM
tCheesy's Avatar
Default trunk led
Hey Leganza,
We learn something everyday... Im giving u props cause you're just interested in your tC. Who cares if it already was auto on-off ( I didnt know that until I read this thread)
You're just taking pride in your tC. Keep up the good work !!
jesse
Old Apr 14, 2007 | 06:51 PM
Leganza's Avatar
OK. Thanks guys... but I'm so ......... you know..
Anyway I will update the thread so that other people don't get confused...
Hey guys who really don't care about trunk light... Just turn on the switch on trunk light all the time!!!!
Old Oct 22, 2008 | 10:35 PM
scionTCny's Avatar
Default Trunk Light LED
Does any know a LED light to use for the trunk? I've bought map lights from superbrightleds.com. Just need to know the model number for the trunk light. Thanks!
Old Oct 23, 2008 | 01:22 AM
BZinn1's Avatar
Just leave the switch back there and find a new use for it........more lighting.......fans......something.
